ArcGIS.Desktop.TaskAssistant.Exceptions Namespace / OpenTaskException Class
Members Example
    Represents an error exception when opening an ArcGIS Pro .esriTasks file.
    Syntax
    Public NotInheritable Class OpenTaskException
       Inherits TaskException
       Implements System.Runtime.Serialization.ISerializable
    public sealed class OpenTaskException : TaskException, System.Runtime.Serialization.ISerializable
    Remarks
    Example
    Open a Task File - .esriTasks file
    // Open a task file
    try
      // TODO - substitute your own .esriTasks file to be opened
      string taskFile = @"c:\Tasks\Get Started.esriTasks";
      //At 2.x -
      //System.Guid guid = await TaskAssistantModule.OpenTaskAsync(taskFile);
      System.Guid guid;
      if (TaskAssistantFactory.Instance.CanOpenTaskFile(taskFile))
        guid = await TaskAssistantFactory.Instance.OpenTaskFileAsync(taskFile);
      // TODO - retain the guid returned for use with CloseTaskItemAsync
    catch (OpenTaskException e)
      // exception thrown if task file doesn't exist or has incorrect format
      ArcGIS.Desktop.Framework.Dialogs.MessageBox.Show(e.Message);
    Open a Project Task Item
      // get the first project task item
      var taskItem = Project.Current.GetItems<TaskProjectItem>().FirstOrDefault();
      // if there isn't a project task item, return
      if (taskItem == null)
        return;
      try
        // Open it
        //At 2.x -
        //System.Guid guid = await TaskAssistantModule.OpenTaskItemAsync(taskItem.TaskItemGuid);
        var guid = await TaskAssistantFactory.Instance.OpenTaskItemAsync(taskItem.TaskItemGuid);
    Get Task Information - from a TaskProjectItem
        return;
      string message = await QueuedTask.Run(async () =>
        bool isOpen = taskItem.IsOpen;
        Guid taskGuid = taskItem.TaskItemGuid;
        string msg = "";
        try
          TaskItemInfo taskItemInfo = await taskItem.GetTaskItemInfoAsync();
          msg = "Name : " + taskItemInfo.Name;
          msg += "\r\n" + "Description : " + taskItemInfo.Description;
          msg += "\r\n" + "Guid : " + taskItemInfo.Guid.ToString("B");
          msg += "\r\n" + "Task Count : " + taskItemInfo.GetTasks().Count();
          // iterate the tasks in the task item
          IEnumerable<TaskInfo> taskInfos = taskItemInfo.GetTasks();
          foreach (TaskInfo taskInfo in taskInfos)
            string name = taskInfo.Name;
            Guid guid = taskInfo.Guid;
            // do something
          msg = e.Message;
        catch (TaskFileVersionException e)
          // exception thrown if task file does not support returning task information
          msg = e.Message;
        return msg;
      ArcGIS.Desktop.Framework.Dialogs.MessageBox.Show(message, "Task Information");
    Get Task Information - from an .esriTasks file
        string msg = "";
        try
          // retrieve the task item information
          //At 2.x -
          //TaskItemInfo taskItemInfo = await TaskAssistantModule.GetTaskItemInfoAsync(taskFile);
          TaskItemInfo taskItemInfo = await TaskAssistantFactory.Instance.GetTaskItemInfoAsync(taskFile);
          msg = e.Message;
          msg = e.Message;
        return msg;
    Open a specific Task in a Task File - .esriTasks file
        try
          //At 2.x -
          var taskItemInfo = await TaskAssistantFactory.Instance.GetTaskItemInfoAsync(taskFile);
          // find the first task
          TaskInfo taskInfo = taskItemInfo.GetTasks().FirstOrDefault();
          Guid guid = Guid.Empty;
          if (taskInfo != null)
            // if a task exists, open it
            //At 2.x -
            //guid = await TaskAssistantModule.OpenTaskAsync(taskFile, taskInfo.Guid);
            guid = await TaskAssistantFactory.Instance.OpenTaskFileAsync(taskFile, taskInfo.Guid);
          else
            // else just open the task item
            //At 2.x -
            //guid = await TaskAssistantModule.OpenTaskAsync(taskFile);
    Inheritance Hierarchy
    System.Object
       System.Exception
          ArcGIS.Desktop.TaskAssistant.Exceptions.TaskException
             ArcGIS.Desktop.TaskAssistant.Exceptions.OpenTaskException
    Requirements
