ArcGIS.Desktop.TaskAssistant.Exceptions Namespace / TaskFileVersionException Class
Members Example
    Represents an error exception when the ArcGIS Pro .esriTasks file has the incorrect version.
    Syntax
    Public NotInheritable Class TaskFileVersionException
       Inherits TaskException
       Implements System.Runtime.Serialization.ISerializable
    public sealed class TaskFileVersionException : TaskException, System.Runtime.Serialization.ISerializable
    Remarks
    The TaskFileVersionException is thrown from the GetTaskItemInfoAsync or ArcGIS.Desktop.TaskAssistant.TaskProjectItem.GetTaskItemInfoAsync methods. Use the Message property to determine the error in opening the task file.
    Example
    Get Task Information - from a TaskProjectItem
      var taskItem = Project.Current.GetItems<TaskProjectItem>().FirstOrDefault();
      // if there isn't a project task item, return
      if (taskItem == null)
        return;
      string message = await QueuedTask.Run(async () =>
        bool isOpen = taskItem.IsOpen;
        Guid taskGuid = taskItem.TaskItemGuid;
        string msg = "";
        try
          TaskItemInfo taskItemInfo = await taskItem.GetTaskItemInfoAsync();
          msg = "Name : " + taskItemInfo.Name;
          msg += "\r\n" + "Description : " + taskItemInfo.Description;
          msg += "\r\n" + "Guid : " + taskItemInfo.Guid.ToString("B");
          msg += "\r\n" + "Task Count : " + taskItemInfo.GetTasks().Count();
          // iterate the tasks in the task item
          IEnumerable<TaskInfo> taskInfos = taskItemInfo.GetTasks();
          foreach (TaskInfo taskInfo in taskInfos)
            string name = taskInfo.Name;
            Guid guid = taskInfo.Guid;
            // do something
        catch (OpenTaskException e)
          // exception thrown if task file doesn't exist or has incorrect format
          msg = e.Message;
        catch (TaskFileVersionException e)
          // exception thrown if task file does not support returning task information
          msg = e.Message;
        return msg;
      ArcGIS.Desktop.Framework.Dialogs.MessageBox.Show(message, "Task Information");
    Get Task Information - from an .esriTasks file
      // TODO - substitute your own .esriTasks file
      string taskFile = @"c:\Tasks\Get Started.esriTasks";
        string msg = "";
        try
          // retrieve the task item information
          //At 2.x -
          //TaskItemInfo taskItemInfo = await TaskAssistantModule.GetTaskItemInfoAsync(taskFile);
          TaskItemInfo taskItemInfo = await TaskAssistantFactory.Instance.GetTaskItemInfoAsync(taskFile);
          msg = e.Message;
          msg = e.Message;
        return msg;
    Open a specific Task in a Task File - .esriTasks file
      // TODO - substitute your own .esriTasks file to be opened
        try
          //At 2.x -
          var taskItemInfo = await TaskAssistantFactory.Instance.GetTaskItemInfoAsync(taskFile);
          // find the first task
          TaskInfo taskInfo = taskItemInfo.GetTasks().FirstOrDefault();
          Guid guid = Guid.Empty;
          if (taskInfo != null)
            // if a task exists, open it
            //At 2.x -
            //guid = await TaskAssistantModule.OpenTaskAsync(taskFile, taskInfo.Guid);
            guid = await TaskAssistantFactory.Instance.OpenTaskFileAsync(taskFile, taskInfo.Guid);
          else
            // else just open the task item
            //At 2.x -
            //guid = await TaskAssistantModule.OpenTaskAsync(taskFile);
            guid = await TaskAssistantFactory.Instance.OpenTaskFileAsync(taskFile);
          // TODO - retain the guid returned for use with CloseTaskItemAsync
          ArcGIS.Desktop.Framework.Dialogs.MessageBox.Show(e.Message);
    Inheritance Hierarchy
    System.Object
       System.Exception
          ArcGIS.Desktop.TaskAssistant.Exceptions.TaskException
             ArcGIS.Desktop.TaskAssistant.Exceptions.TaskFileVersionException
    Requirements
