Public Function GetTaskItemInfoAsync() As Task(Of TaskItemInfo)
public Task<TaskItemInfo> GetTaskItemInfoAsync()
| Exception | Description |
| ArcGIS.Desktop.TaskAssistant.Exceptions.OpenTaskException | Error opening the task file. For example the taskFile is invalid. |
| ArcGIS.Desktop.TaskAssistant.Exceptions.TaskFileVersionException | Error opening the task file. The task item has the incorrect version. |
| ArcGIS.Core.CalledOnWrongThreadException | This method or property must be called within the lambda passed to QueuedTask.Run. |
var taskItem = Project.Current.GetItems<TaskProjectItem>().FirstOrDefault();
// if there isn't a project task item, return
if (taskItem == null)
return;
string message = await QueuedTask.Run(async () =>
bool isOpen = taskItem.IsOpen;
Guid taskGuid = taskItem.TaskItemGuid;
string msg = "";
try
TaskItemInfo taskItemInfo = await taskItem.GetTaskItemInfoAsync();
msg = "Name : " + taskItemInfo.Name;
msg += "\r\n" + "Description : " + taskItemInfo.Description;
msg += "\r\n" + "Guid : " + taskItemInfo.Guid.ToString("B");
msg += "\r\n" + "Task Count : " + taskItemInfo.GetTasks().Count();
// iterate the tasks in the task item
IEnumerable<TaskInfo> taskInfos = taskItemInfo.GetTasks();
foreach (TaskInfo taskInfo in taskInfos)
string name = taskInfo.Name;
Guid guid = taskInfo.Guid;
// do something
catch (OpenTaskException e)
// exception thrown if task file doesn't exist or has incorrect format
msg = e.Message;
catch (TaskFileVersionException e)
// exception thrown if task file does not support returning task information
msg = e.Message;
return msg;
ArcGIS.Desktop.Framework.Dialogs.MessageBox.Show(message, "Task Information");
