ArcGIS.Core.CIM Namespace / CIMFeatureTable Class
    CIMFeatureTable Class Properties
    For a list of all members of this type, see CIMFeatureTable members.
    Public Properties
     NameDescription
    Public Property Gets or sets the active range name. (Inherited from ArcGIS.Core.CIM.CIMDisplayTable)
    Public Property Gets or sets the bind variables. (Inherited from ArcGIS.Core.CIM.CIMDisplayTable)
    Public PropertyGets or sets overrides for database relationships as relationship info. By default this property is null. This will contain relationship info elements for those database relationships that have overrides. (Inherited from ArcGIS.Core.CIM.CIMDisplayTable)
    Public Property Gets or sets the data connection.
    Public Property Gets or sets the definition expression that can subset the rows in the layer or table. (Inherited from ArcGIS.Core.CIM.CIMDisplayTable)
    Public Property Gets or sets the name of the active definition expression. (Inherited from ArcGIS.Core.CIM.CIMDisplayTable)
    Public Property Gets or sets the definition filter choices. (Inherited from ArcGIS.Core.CIM.CIMDisplayTable)
    Public Property Gets or sets the DefinitionSet for the table.
    Public PropertyGets or sets the expression information used for coming up with a string that represents a row or a feature. This property takes precedence over DisplayField. (Inherited from ArcGIS.Core.CIM.CIMDisplayTable)
    Public Property Gets or sets the name of the attribute field that will be used as a label that represents each row in the layer or table. The display field must be able to be represented as a string (string or numeric). (Inherited from ArcGIS.Core.CIM.CIMDisplayTable)
    Public Property Gets or sets a value indicating whether or not the layer or table can be edited. (Inherited from ArcGIS.Core.CIM.CIMDisplayTable)
    Public Property Gets or sets the field descriptions. Field descriptions for fields may only be written if values are overridden from defaults. (Inherited from ArcGIS.Core.CIM.CIMDisplayTable)
    Public Property Gets or sets floor-aware properties for the layer or table used in floor filtering. (Inherited from ArcGIS.Core.CIM.CIMDisplayTable)
    Public Property Gets or sets the form information for the layer or table. (Inherited from ArcGIS.Core.CIM.CIMDisplayTable)
    Public Property Gets or sets a value indicating whether the data source is licensed.
    Public Property Gets or sets the range definitions. (Inherited from ArcGIS.Core.CIM.CIMDisplayTable)
    Public Property Gets or sets the relates. (Inherited from ArcGIS.Core.CIM.CIMDisplayTable)
    Public Property Gets or sets the route identifier field of a route feature class. (Inherited from ArcGIS.Core.CIM.CIMDisplayTable)
    Public Property Gets or sets the search order option.
    Public Property Gets or sets the URI of the selection set for the layer or table. (Inherited from ArcGIS.Core.CIM.CIMDisplayTable)
    Public Property Gets or sets a value indicating whether related data should be selected when creating a new selection. (Inherited from ArcGIS.Core.CIM.CIMDisplayTable)
    Public Property Gets or sets an area that can be used to subset the rows in the virtual table.
    Public Property Gets or sets the study area spatial relationship.
    Public Property Gets or sets the subtype value that should be used in the feature layer definition. This property is honored only when feature layer is a member of SubtypeLayer. (Inherited from ArcGIS.Core.CIM.CIMDisplayTable)
    Public Property Gets or sets the time definition. (Inherited from ArcGIS.Core.CIM.CIMDisplayTable)
    Public Property Gets or sets the time definition fields. (Inherited from ArcGIS.Core.CIM.CIMDisplayTable)
    Public Property Gets or sets the time display definition. (Inherited from ArcGIS.Core.CIM.CIMDisplayTable)
    Public Property Gets or sets the time fields. (Inherited from ArcGIS.Core.CIM.CIMDisplayTable)
    Public Property Gets or sets a value indicating whether or not the SubtypeValue should be used. (Inherited from ArcGIS.Core.CIM.CIMDisplayTable)
    Top
