ArcGIS.Core.Data.DDL Namespace / RelationshipClassDescription Class / RelationshipClassDescription Constructor / RelationshipClassDescription Constructor(String,TableDescription,TableDescription,RelationshipCardinality,String,String)
The name of the description.
The origin class of the ArcGIS.Core.Data.RelationshipClass.
The destination class of the ArcGIS.Core.Data.RelationshipClass.
The relationship cardinality of the ArcGIS.Core.Data.RelationshipClass.
The name of the ArcGIS.Core.Data.Field in the origin class that serves as the origin primary key.
The name of the ArcGIS.Core.Data.Field in the destination class that serves as the origin foreign key.
Example
    Creates a description object of the ArcGIS.Core.Data.RelationshipClass.
    Syntax
    Parameters
    relationshipClassName
    originClassDescription
    destinationClassDescription
    relationshipCardinality
    originPrimaryKey
    originForeignKey
    Exceptions
    Example
    Creating relationship class
      // Must be called within QueuedTask.Run
      void CreateRelationshipWithRelationshipRules(SchemaBuilder schemaBuilder)
        // Creating a 'BuildingType' table with two fields - BuildingType and BuildingTypeDescription
        FieldDescription buildingType = FieldDescription.CreateIntegerField("BuildingType");
        FieldDescription buildingTypeeDescription = FieldDescription.CreateStringField("BuildingTypeDescription", 100);
        TableDescription buildingTypeDescription = new TableDescription("BuildingType",
          new List<FieldDescription>() { buildingType, buildingTypeeDescription });
        TableToken buildingtypeToken = schemaBuilder.Create(buildingTypeDescription);
        // Creating a 'Building' feature class with three fields - BuildingId, Address, and BuildingType
        FieldDescription buildingId = FieldDescription.CreateIntegerField("BuildingId");
        FieldDescription buildingAddress = FieldDescription.CreateStringField("Address", 100);
        FieldDescription usageSubType = FieldDescription.CreateIntegerField("UsageSubtype");
        FeatureClassDescription featureClassDescription = new FeatureClassDescription("Building",
          new List<FieldDescription> { buildingId, buildingAddress, buildingType, usageSubType },
          new ShapeDescription(GeometryType.Polygon, SpatialReferences.WGS84));
        // Set subtype details (optional)
        featureClassDescription.SubtypeFieldDescription = new SubtypeFieldDescription(usageSubType.Name,
          new Dictionary<int, string> { { 1, "Marketing" }, { 2, "Utility" } });
        FeatureClassToken buildingToken = schemaBuilder.Create(featureClassDescription);
        // Creating a 1:M relationship between the 'Building' feature class and 'BuildingType' table
        RelationshipClassDescription relationshipClassDescription = new RelationshipClassDescription(
          "BuildingToBuildingType", new FeatureClassDescription(buildingToken), new TableDescription(buildingtypeToken),
          RelationshipCardinality.OneToMany, buildingType.Name, buildingType.Name)
          RelationshipType = RelationshipType.Composite
        // Adding relationship rules for the 'Marketing' subtype
        relationshipClassDescription.RelationshipRuleDescriptions.Add(new RelationshipRuleDescription(1, null));
        schemaBuilder.Create(relationshipClassDescription);
        schemaBuilder.Build();
    Requirements
    ArcGIS Pro version: 3.1 or higher.
