Public Class TableDescription Inherits Description
public class TableDescription : Description
// Must be called within QueuedTask.Run
void RenameTableSnippet(Geodatabase geodatabase)
// Renaming a table from 'Original_Table' to 'Renamed_Table'
string tableToBeRenamed = "Original_Table";
string tableRenameAs = "Renamed_Table";
TableDefinition tableDefinition = geodatabase.GetDefinition<TableDefinition>(tableToBeRenamed);
SchemaBuilder schemaBuilder = new SchemaBuilder(geodatabase);
// Table rename
schemaBuilder.Rename(new TableDescription(tableDefinition), tableRenameAs);
schemaBuilder.Build();
void RemoveFieldTableSnippet(Geodatabase geodatabase)
// Removing all fields from 'Parcels' table except following
// Tax_Code
// Parcel_Address
// The table to remove fields
string tableName = "Parcels";
TableDefinition tableDefinition = geodatabase.GetDefinition<TableDefinition>(tableName);
IReadOnlyList<Field> fields = tableDefinition.GetFields();
// Existing fields from 'Parcels' table
Field taxCodeField = fields.First(f => f.Name.Equals("Tax_Code"));
Field parcelAddressField = fields.First(f => f.Name.Equals("Parcel_Address"));
FieldDescription taxFieldDescription = new FieldDescription(taxCodeField);
FieldDescription parcelAddressFieldDescription = new FieldDescription(parcelAddressField);
// Fields to retain in modified table
List<FieldDescription> fieldsToBeRetained = new List<FieldDescription>()
taxFieldDescription, parcelAddressFieldDescription
// New description of the 'Parcels' table with the 'Tax_Code' and 'Parcel_Address' fields
TableDescription modifiedTableDescription = new TableDescription(tableName, fieldsToBeRetained);
// Remove all fields except the 'Tax_Code' and 'Parcel_Address' fields
schemaBuilder.Modify(modifiedTableDescription);
System.Object
ArcGIS.Core.Data.DDL.Description
ArcGIS.Core.Data.DDL.TableDescription
ArcGIS.Core.Data.DDL.FeatureClassDescription
