ArcGIS.Core.Data.DDL Namespace / SchemaBuilder Class / AddRelationshipClass Method / AddRelationshipClass(FeatureDatasetDescription,RelationshipClassDescription) Method
Indicates the ArcGIS.Core.Data.FeatureDataset where the ArcGIS.Core.Data.RelationshipClass will be added.
Indicates the ArcGIS.Core.Data.RelationshipClass to add.
Example
    Enqueue the Add operation on the object referred to by the FeatureDatasetDescription and the RelationshipClassDescription.
    Syntax
    Parameters
    featureDatasetDescription
    relationshipClassDescription
    Exceptions
    ExceptionDescription
    The relationship split policy and/or the relationship rules are invalid.
    featureDatasetDescription and/or relationshipClassDescription is null.
    Memory ArcGIS.Core.Data.Geodatabase does not support relationship classes.
    The relationship split policy is not supported.
    Example
    Adding/Removing Relationship class in/out of a feature dataset
      // Must be called within QueuedTask.Run
      void MoveRelationshipClass(SchemaBuilder schemaBuilder, FeatureDatasetDefinition featureDatasetDefinition, RelationshipClassDefinition relationshipClassDefinition)
        FeatureDatasetDescription featureDatasetDescription = new FeatureDatasetDescription(featureDatasetDefinition);
        RelationshipClassDescription relationshipClassDescription = new RelationshipClassDescription(relationshipClassDefinition);
        // Remove relationship class from the feature dataset
        schemaBuilder.RemoveRelationshipClass(featureDatasetDescription, relationshipClassDescription);
        // Add relationship class inside the feature dataset
        // schemaBuilder.AddRelationshipClass(featureDatasetDescription, relationshipClassDescription);
        schemaBuilder.Build();
    Requirements
    ArcGIS Pro version: 3.1 or higher.
