ArcGIS.Core.Data.DDL Namespace / FeatureDatasetDescription Class
Members Example
    Represents a mechanism to create a ArcGIS.Core.Data.FeatureDataset.
    Object Model
    FeatureDatasetDescription ClassSpatialReference Class
    Syntax
    public class FeatureDatasetDescription : Description
    Public Class FeatureDatasetDescription
       Inherits Description
    Example
    Creating an annotation feature class inside feature dataset
      Task CreateAnnotationFeatureClassUsingExistingAnnotationFeatureClassInDatasetAsync(
        Geodatabase geodatabase) => QueuedTask.Run(() =>
        // Create a Cities annotation feature class inside Places feature dataset using existing annotation feature class
        // Feature dataset name
        string featureDatasetName = "Places";
        // Annotation feature class name
        string annotationFeatureClassName = "CitiesAnnotation";
        // Create a SchemaBuilder object
        SchemaBuilder schemaBuilder = new SchemaBuilder(geodatabase);
        // Open existing annotation feature class name
        using (AnnotationFeatureClass existingAnnotationFeatureClass = geodatabase.OpenDataset<AnnotationFeatureClass>("ExistingAnnotationFeatureClass"))
          // Create Feature dataset description
          FeatureDatasetDescription featureDatasetDescription = new FeatureDatasetDescription(featureDatasetName, existingAnnotationFeatureClass.GetDefinition().GetSpatialReference());
          // Add the creation of the Places dataset to DDL task
          FeatureDatasetToken featureDatasetToken = schemaBuilder.Create(featureDatasetDescription);
          // Create an annotation feature class description using existing annotation feature class
          AnnotationFeatureClassDescription annotationFeatureClassDescription = new AnnotationFeatureClassDescription(annotationFeatureClassName,
              existingAnnotationFeatureClass.GetDefinition())
            IsAutoCreate = true,
            IsSymbolIDRequired = false,
            IsUpdatedOnShapeChange = true
          // Add the creation of the Cities annotation feature class inside Places feature dataset
          schemaBuilder.Create(new FeatureDatasetDescription(featureDatasetToken),
            annotationFeatureClassDescription);
          // Execute the DDL
          bool success = schemaBuilder.Build();
          // Inspect error messages
          if (!success)
            IReadOnlyList<string> errorMessages = schemaBuilder.ErrorMessages;
            //etc.
    Inheritance Hierarchy
    System.Object
       ArcGIS.Core.Data.DDL.Description
          ArcGIS.Core.Data.DDL.FeatureDatasetDescription
    Requirements
