ArcGIS.Core.Data.DDL Namespace / SchemaBuilder Class / Create Method / Create(RelationshipClassDescription) Method
Indicates the ArcGIS.Core.Data.RelationshipClass to be created.
Example
    Enqueue the create operation on the object referred to by the RelationshipClassDescription. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Parameters
    relationshipClassDescription
    Return Value
    Exceptions
    ExceptionDescription
    The relationship split policy and/or the relationship rules are invalid.
    relationshipClassDescription is null.
    Memory ArcGIS.Core.Data.Geodatabase does not support relationship classes.
    The relationship split policy is not supported.
    Example
    Creating a table with index from scratch
      // Must be called within QueuedTask.Run
      void CreatingTableWithIndex(SchemaBuilder schemaBuilder)
        FieldDescription nameFieldDescription = FieldDescription.CreateStringField("Name", 50);
        FieldDescription addressFieldDescription = FieldDescription.CreateStringField("Address", 200);
        // Creating a feature class, 'Buildings' with two fields
        TableDescription tableDescription = new TableDescription("Buildings",
          new List<FieldDescription>() { nameFieldDescription, addressFieldDescription });
        // Enqueue DDL operation to create a table
        TableToken tableToken = schemaBuilder.Create(tableDescription);
        // Creating an attribute index named as 'Idx'
        AttributeIndexDescription attributeIndexDescription = new AttributeIndexDescription("Idx", new TableDescription(tableToken),
          new List<string> { nameFieldDescription.Name, addressFieldDescription.Name });
        // Enqueue DDL operation to create an attribute index
        schemaBuilder.Create(attributeIndexDescription);
        // Execute build indexes operation
        bool isBuildSuccess = schemaBuilder.Build();
    Adding indexes in pre-existing dataset
      void AddingIndexes(SchemaBuilder schemaBuilder, FeatureClassDefinition featureClassDefinition)
        // Field names to add in the attribute index
        string fieldName = featureClassDefinition.GetFields().First(f => f.AliasName.Contains("Name")).Name;
        string fieldAddress = featureClassDefinition.GetFields().First(f => f.AliasName.Contains("Address")).Name;
        // Creating an attribute index with index name 'Idx' and two participating fields' name
          new TableDescription(featureClassDefinition), new List<string> { fieldName, fieldAddress });
        // Enqueue DDL operation for an attribute index creation
        // Creating the spatial index
        SpatialIndexDescription spatialIndexDescription = new SpatialIndexDescription(new FeatureClassDescription(featureClassDefinition));
        // Enqueue DDL operation for the spatial index creation
        schemaBuilder.Create(spatialIndexDescription);
        if (!isBuildSuccess)
          IReadOnlyList<string> errors = schemaBuilder.ErrorMessages;
          // Iterate and handle errors
    Creating table with subtypes
      void CreateTableWithSubtypes(SchemaBuilder schemaBuilder)
        // Creating a 'Building' table with the subtype field 'BuildingType'
        FieldDescription buildingType = new FieldDescription("BuildingType", FieldType.Integer);
        FieldDescription buildingName = new FieldDescription("Name", FieldType.String);
        TableDescription tableDescription = new TableDescription("Building", new List<FieldDescription> { buildingName, buildingType });
        // Add the building type subtype with three subtypes - Business, Marketing, Security
        tableDescription.SubtypeFieldDescription = new SubtypeFieldDescription(buildingType.Name,
          new Dictionary<int, string> { { 1, "Business" }, { 2, "Marketing" }, { 3, "Security" } })
          DefaultSubtypeCode = 3 // Assigning 'Security' building type as the default subtype
    Creating relationship class
      void CreateRelationshipWithRelationshipRules(SchemaBuilder schemaBuilder)
        // Creating a 'BuildingType' table with two fields - BuildingType and BuildingTypeDescription
        FieldDescription buildingType = FieldDescription.CreateIntegerField("BuildingType");
        FieldDescription buildingTypeeDescription = FieldDescription.CreateStringField("BuildingTypeDescription", 100);
        TableDescription buildingTypeDescription = new TableDescription("BuildingType",
          new List<FieldDescription>() { buildingType, buildingTypeeDescription });
        TableToken buildingtypeToken = schemaBuilder.Create(buildingTypeDescription);
        // Creating a 'Building' feature class with three fields - BuildingId, Address, and BuildingType
        FieldDescription buildingId = FieldDescription.CreateIntegerField("BuildingId");
        FieldDescription buildingAddress = FieldDescription.CreateStringField("Address", 100);
        FieldDescription usageSubType = FieldDescription.CreateIntegerField("UsageSubtype");
        FeatureClassDescription featureClassDescription = new FeatureClassDescription("Building",
          new List<FieldDescription> { buildingId, buildingAddress, buildingType, usageSubType },
          new ShapeDescription(GeometryType.Polygon, SpatialReferences.WGS84));
        // Set subtype details (optional)
        featureClassDescription.SubtypeFieldDescription = new SubtypeFieldDescription(usageSubType.Name,
          new Dictionary<int, string> { { 1, "Marketing" }, { 2, "Utility" } });
        FeatureClassToken buildingToken = schemaBuilder.Create(featureClassDescription);
        // Creating a 1:M relationship between the 'Building' feature class and 'BuildingType' table
        RelationshipClassDescription relationshipClassDescription = new RelationshipClassDescription(
          "BuildingToBuildingType", new FeatureClassDescription(buildingToken), new TableDescription(buildingtypeToken),
          RelationshipCardinality.OneToMany, buildingType.Name, buildingType.Name)
          RelationshipType = RelationshipType.Composite
        // Adding relationship rules for the 'Marketing' subtype
        relationshipClassDescription.RelationshipRuleDescriptions.Add(new RelationshipRuleDescription(1, null));
        schemaBuilder.Create(relationshipClassDescription);
    Creating attributed relationship class
      void CreateAttributedRelationship(SchemaBuilder schemaBuilder)
          new List<FieldDescription> { buildingId, buildingAddress, buildingType },
        // Creating M:M relationship between the 'Building' feature class and 'BuildingType' table
        AttributedRelationshipClassDescription attributedRelationshipClassDescription =
          new AttributedRelationshipClassDescription("BuildingToBuildingType",
            new TableDescription(buildingtypeToken), RelationshipCardinality.ManyToMany, "OBJECTID", "BuildingID",
            "OBJECTID", "BuildingTypeID");
        // Adding optional attribute field in the intermediate table - 'OwnershipPercentage' field
        attributedRelationshipClassDescription.FieldDescriptions.Add(FieldDescription.CreateIntegerField("OwnershipPercentage"));
        schemaBuilder.Create(attributedRelationshipClassDescription);
    Requirements
    ArcGIS Pro version: 3.1 or higher.
