ArcGIS.Core.Data.DDL Namespace / SchemaBuilder Class / Create Method
    Create Method (SchemaBuilder)
    Overload List
    OverloadDescription
    Enqueue the create operation on the object referred to by the TableDescription.
    Enqueue the create operation on the object referred to by the FeatureClassDescription. This method must be called on the MCT. Use QueuedTask.Run.
    Enqueue the create operation on the object referred to by the ArcGIS.Core.Data.DDL.Knowledge.KnowledgeGraphTypeDescription. This method must be called on the MCT. Use QueuedTask.Run.
    Enqueue the create operation on the object referred to by the AnnotationFeatureClassDescription. This method must be called on the MCT. Use QueuedTask.Run.
    Enqueue the create operation on the object referred to by the DimensionFeatureClassDescription. This method must be called on the MCT. Use QueuedTask.Run.
    Enqueue the create operation on the object referred to by the CodedValueDomainDescription. This method must be called on the MCT. Use QueuedTask.Run.
    Enqueue the create operation on the object referred to by the RangeDomainDescription. This method must be called on the MCT. Use QueuedTask.Run.
    Enqueue the create operation on the object referred to by the FeatureDatasetDescription. This method must be called on the MCT. Use QueuedTask.Run.
    Enqueue the create operation on the object referred to by the RelationshipClassDescription. This method must be called on the MCT. Use QueuedTask.Run.
    Enqueue the create operation on the object referred to by the AttributedRelationshipClassDescription. This method must be called on the MCT. Use QueuedTask.Run.
    Enqueue the create operation on the object referred to by the IndexDescription. This method must be called on the MCT. Use QueuedTask.Run.
    Requirements
