ArcGIS.Core.Data.DDL Namespace / SchemaBuilder Class / Create Method / Create(AnnotationFeatureClassDescription) Method
Indicates the ArcGIS.Core.Data.Mapping.AnnotationFeatureClass to be created.
Example
    Enqueue the create operation on the object referred to by the AnnotationFeatureClassDescription. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Exceptions
    ExceptionDescription
    Memory ArcGIS.Core.Data.Geodatabase does not support feature-linked annotation feature classes.
    -or-
    The total path length for the ArcGIS.Core.Data.Mapping.AnnotationFeatureClass to be created must be less than 252 characters.
    -or-
    The annotation symbols are invalid.
    annotationFeatureClassDescription is null.
    Remarks
    Example
    Creating an annotation feature class
      // Must be called within QueuedTask.Run
      void CreateStandAloneAnnotationFeatureClass(
        Geodatabase geodatabase, SpatialReference spatialReference)
        // Creating a Cities annotation feature class
        // with following user defined fields
        // Name
        // GlobalID
        // Annotation feature class name
        string annotationFeatureClassName = "CitiesAnnotation";
        // Create user defined attribute fields for annotation feature class
        FieldDescription globalIDFieldDescription = FieldDescription.CreateGlobalIDField();
        FieldDescription nameFieldDescription = FieldDescription.CreateStringField("Name", 255);
        // Create a list of all field descriptions
        List<FieldDescription> fieldDescriptions = new List<FieldDescription>
            { globalIDFieldDescription, nameFieldDescription };
        // Create a ShapeDescription object
        ShapeDescription shapeDescription = new ShapeDescription(GeometryType.Polygon, spatialReference);
        // Create general placement properties for Maplex engine
        CIMMaplexGeneralPlacementProperties generalPlacementProperties =
          new CIMMaplexGeneralPlacementProperties
            AllowBorderOverlap = true,
            PlacementQuality = MaplexQualityType.High,
            DrawUnplacedLabels = true,
            InvertedLabelTolerance = 1.0,
            RotateLabelWithDisplay = true,
            UnplacedLabelColor = new CIMRGBColor
              R = 0,
              G = 255,
              B = 0,
              Alpha = 0.5f // Green
        // Create general placement properties for Standard engine
        //CIMStandardGeneralPlacementProperties generalPlacementProperties =
        //  new CIMStandardGeneralPlacementProperties
        //    DrawUnplacedLabels = true,
        //    InvertedLabelTolerance = 3.0,
        //    RotateLabelWithDisplay = true,
        //    UnplacedLabelColor = new CIMRGBColor
        //      R = 255, G = 0, B = 0, Alpha = 0.5f // Red
        // Create annotation  label classes
        // Green label
        CIMLabelClass greenLabelClass = new CIMLabelClass
          Name = "Green",
          ExpressionTitle = "Expression-Green",
          ExpressionEngine = LabelExpressionEngine.Arcade,
          Expression = "$feature.OBJECTID",
          ID = 1,
          Priority = 0,
          Visibility = true,
          TextSymbol = new CIMSymbolReference
            Symbol = new CIMTextSymbol()
              Angle = 45,
              FontType = FontType.Type1,
              FontFamilyName = "Tahoma",
              FontEffects = FontEffects.Normal,
              HaloSize = 2.0,
              Symbol = new CIMPolygonSymbol
                SymbolLayers = new CIMSymbolLayer[]
                    new CIMSolidFill
                      Color = CIMColor.CreateRGBColor(0, 255, 0)
                UseRealWorldSymbolSizes = true
            MaxScale = 0,
            MinScale = 0,
            SymbolName = "TextSymbol-Green"
          StandardLabelPlacementProperties = new CIMStandardLabelPlacementProperties
            AllowOverlappingLabels = true,
            LineOffset = 1.0
          MaplexLabelPlacementProperties = new CIMMaplexLabelPlacementProperties
            AlignLabelToLineDirection = true,
            AvoidPolygonHoles = true
        // Blue label
        CIMLabelClass blueLabelClass = new CIMLabelClass
          Name = "Blue",
          ExpressionTitle = "Expression-Blue",
          ID = 2,
          Priority = 0,
          Visibility = true,
              Angle = 45,
              FontFamilyName = "Consolas",
              HaloSize = 2.0,
                    new CIMSolidFill
                      Color = CIMColor.CreateRGBColor(0, 0, 255)
            MaxScale = 0,
            MinScale = 0,
            SymbolName = "TextSymbol-Blue"
            LineOffset = 1.0
        // Create a list of labels
        List<CIMLabelClass> labelClasses = new List<CIMLabelClass> { greenLabelClass, blueLabelClass };
        // Create an annotation feature class description object to describe the feature class to create
        AnnotationFeatureClassDescription annotationFeatureClassDescription =
          new AnnotationFeatureClassDescription(annotationFeatureClassName, fieldDescriptions, shapeDescription,
            generalPlacementProperties, labelClasses)
            IsAutoCreate = true,
            IsSymbolIDRequired = false,
            IsUpdatedOnShapeChange = true
        // Create a SchemaBuilder object
        SchemaBuilder schemaBuilder = new SchemaBuilder(geodatabase);
        // Add the creation of the Cities annotation feature class to the list of DDL tasks
        schemaBuilder.Create(annotationFeatureClassDescription);
        // Execute the DDL
        bool success = schemaBuilder.Build();
        // Inspect error messages
        if (!success)
          IReadOnlyList<string> errorMessages = schemaBuilder.ErrorMessages;
          //etc.
    Creating a feature-linked annotation feature class
      void CreateFeatureLinkedAnnotationFeatureClass(Geodatabase geodatabase,
        // Creating a feature-linked annotation feature class between water pipe and valve in water distribution network
        // PipeName
        // GlobalID
        string annotationFeatureClassName = "WaterPipeAnnotation";
        FieldDescription pipeGlobalID = FieldDescription.CreateGlobalIDField();
            { pipeGlobalID, nameFieldDescription };
        CIMMaplexGeneralPlacementProperties generalPlacementProperties = new CIMMaplexGeneralPlacementProperties
            R = 255,
            G = 0,
            B = 0,
            Alpha = 0.5f
        // Green label
          Name = "Green",
          ID = 1,
          Priority = 0,
          Visibility = true,
              Angle = 45,
              HaloSize = 2.0,
                    new CIMSolidFill
            MaxScale = 0,
            MinScale = 0,
            LineOffset = 1.0
        // Blue label
          Name = "Blue",
          ID = 2,
          Priority = 0,
          Visibility = true,
              Angle = 45,
              HaloSize = 2.0,
                    new CIMSolidFill
            MaxScale = 0,
            MinScale = 0,
            LineOffset = 1.0
        // Create linked feature description
        // Linked feature class name
        string linkedFeatureClassName = "WaterPipe";
        // Create fields for water pipe
        FieldDescription waterPipeGlobalID = FieldDescription.CreateGlobalIDField();
        FieldDescription pipeName = FieldDescription.CreateStringField("PipeName", 255);
        // Create a list of water pipe field descriptions
        List<FieldDescription> pipeFieldDescriptions = new List<FieldDescription> { waterPipeGlobalID, pipeName };
        // Create a linked feature class description
        FeatureClassDescription linkedFeatureClassDescription = new FeatureClassDescription(linkedFeatureClassName,
          pipeFieldDescriptions,
          new ShapeDescription(GeometryType.Polyline, spatialReference));
        // Add the creation of the linked feature class to the list of DDL tasks
        FeatureClassToken linkedFeatureClassToken = schemaBuilder.Create(linkedFeatureClassDescription);
            generalPlacementProperties, labelClasses, new FeatureClassDescription(linkedFeatureClassToken))
        // Add the creation of the annotation feature class to the list of DDL tasks
        // Execute the DDL
        if (!success)
          //etc.
    Creating a table with index from scratch
      void CreatingTableWithIndex(SchemaBuilder schemaBuilder)
        FieldDescription nameFieldDescription = FieldDescription.CreateStringField("Name", 50);
        FieldDescription addressFieldDescription = FieldDescription.CreateStringField("Address", 200);
        // Creating a feature class, 'Buildings' with two fields
        TableDescription tableDescription = new TableDescription("Buildings",
          new List<FieldDescription>() { nameFieldDescription, addressFieldDescription });
        // Enqueue DDL operation to create a table
        TableToken tableToken = schemaBuilder.Create(tableDescription);
        // Creating an attribute index named as 'Idx'
        AttributeIndexDescription attributeIndexDescription = new AttributeIndexDescription("Idx", new TableDescription(tableToken),
          new List<string> { nameFieldDescription.Name, addressFieldDescription.Name });
        // Enqueue DDL operation to create an attribute index
        schemaBuilder.Create(attributeIndexDescription);
        // Execute build indexes operation
        bool isBuildSuccess = schemaBuilder.Build();
    Adding indexes in pre-existing dataset
      void AddingIndexes(SchemaBuilder schemaBuilder, FeatureClassDefinition featureClassDefinition)
        // Field names to add in the attribute index
        string fieldName = featureClassDefinition.GetFields().First(f => f.AliasName.Contains("Name")).Name;
        string fieldAddress = featureClassDefinition.GetFields().First(f => f.AliasName.Contains("Address")).Name;
        // Creating an attribute index with index name 'Idx' and two participating fields' name
          new TableDescription(featureClassDefinition), new List<string> { fieldName, fieldAddress });
        // Enqueue DDL operation for an attribute index creation
        // Creating the spatial index
        SpatialIndexDescription spatialIndexDescription = new SpatialIndexDescription(new FeatureClassDescription(featureClassDefinition));
        // Enqueue DDL operation for the spatial index creation
        schemaBuilder.Create(spatialIndexDescription);
        if (!isBuildSuccess)
          IReadOnlyList<string> errors = schemaBuilder.ErrorMessages;
          // Iterate and handle errors
    Creating table with subtypes
      void CreateTableWithSubtypes(SchemaBuilder schemaBuilder)
        // Creating a 'Building' table with the subtype field 'BuildingType'
        FieldDescription buildingType = new FieldDescription("BuildingType", FieldType.Integer);
        FieldDescription buildingName = new FieldDescription("Name", FieldType.String);
        TableDescription tableDescription = new TableDescription("Building", new List<FieldDescription> { buildingName, buildingType });
        // Add the building type subtype with three subtypes - Business, Marketing, Security
        tableDescription.SubtypeFieldDescription = new SubtypeFieldDescription(buildingType.Name,
          new Dictionary<int, string> { { 1, "Business" }, { 2, "Marketing" }, { 3, "Security" } })
          DefaultSubtypeCode = 3 // Assigning 'Security' building type as the default subtype
    Creating relationship class
      void CreateRelationshipWithRelationshipRules(SchemaBuilder schemaBuilder)
        // Creating a 'BuildingType' table with two fields - BuildingType and BuildingTypeDescription
        FieldDescription buildingType = FieldDescription.CreateIntegerField("BuildingType");
        FieldDescription buildingTypeeDescription = FieldDescription.CreateStringField("BuildingTypeDescription", 100);
        TableDescription buildingTypeDescription = new TableDescription("BuildingType",
          new List<FieldDescription>() { buildingType, buildingTypeeDescription });
        TableToken buildingtypeToken = schemaBuilder.Create(buildingTypeDescription);
        // Creating a 'Building' feature class with three fields - BuildingId, Address, and BuildingType
        FieldDescription buildingId = FieldDescription.CreateIntegerField("BuildingId");
        FieldDescription buildingAddress = FieldDescription.CreateStringField("Address", 100);
        FieldDescription usageSubType = FieldDescription.CreateIntegerField("UsageSubtype");
        FeatureClassDescription featureClassDescription = new FeatureClassDescription("Building",
          new List<FieldDescription> { buildingId, buildingAddress, buildingType, usageSubType },
          new ShapeDescription(GeometryType.Polygon, SpatialReferences.WGS84));
        // Set subtype details (optional)
        featureClassDescription.SubtypeFieldDescription = new SubtypeFieldDescription(usageSubType.Name,
          new Dictionary<int, string> { { 1, "Marketing" }, { 2, "Utility" } });
        FeatureClassToken buildingToken = schemaBuilder.Create(featureClassDescription);
        // Creating a 1:M relationship between the 'Building' feature class and 'BuildingType' table
        RelationshipClassDescription relationshipClassDescription = new RelationshipClassDescription(
          "BuildingToBuildingType", new FeatureClassDescription(buildingToken), new TableDescription(buildingtypeToken),
          RelationshipCardinality.OneToMany, buildingType.Name, buildingType.Name)
          RelationshipType = RelationshipType.Composite
        // Adding relationship rules for the 'Marketing' subtype
        relationshipClassDescription.RelationshipRuleDescriptions.Add(new RelationshipRuleDescription(1, null));
        schemaBuilder.Create(relationshipClassDescription);
    Creating attributed relationship class
      void CreateAttributedRelationship(SchemaBuilder schemaBuilder)
          new List<FieldDescription> { buildingId, buildingAddress, buildingType },
        // Creating M:M relationship between the 'Building' feature class and 'BuildingType' table
        AttributedRelationshipClassDescription attributedRelationshipClassDescription =
          new AttributedRelationshipClassDescription("BuildingToBuildingType",
            new TableDescription(buildingtypeToken), RelationshipCardinality.ManyToMany, "OBJECTID", "BuildingID",
            "OBJECTID", "BuildingTypeID");
        // Adding optional attribute field in the intermediate table - 'OwnershipPercentage' field
        attributedRelationshipClassDescription.FieldDescriptions.Add(FieldDescription.CreateIntegerField("OwnershipPercentage"));
        schemaBuilder.Create(attributedRelationshipClassDescription);
    Requirements
