Public NotInheritable Class AnnotationFeatureClassDescription Inherits FeatureClassDescription
public sealed class AnnotationFeatureClassDescription : FeatureClassDescription
// Must be called within QueuedTask.Run
void CreateAnnotationFeatureClassUsingExistingAnnotationFeatureClassInDataset(
Geodatabase geodatabase)
// Create a Cities annotation feature class inside Places feature dataset using existing annotation feature class
// Feature dataset name
string featureDatasetName = "Places";
// Annotation feature class name
string annotationFeatureClassName = "CitiesAnnotation";
// Create a SchemaBuilder object
SchemaBuilder schemaBuilder = new SchemaBuilder(geodatabase);
// Open existing annotation feature class name
using (AnnotationFeatureClass existingAnnotationFeatureClass = geodatabase.OpenDataset<AnnotationFeatureClass>("ExistingAnnotationFeatureClass"))
// Create Feature dataset description
FeatureDatasetDescription featureDatasetDescription = new FeatureDatasetDescription(featureDatasetName, existingAnnotationFeatureClass.GetDefinition().GetSpatialReference());
// Add the creation of the Places dataset to DDL task
FeatureDatasetToken featureDatasetToken = schemaBuilder.Create(featureDatasetDescription);
// Create an annotation feature class description using existing annotation feature class
AnnotationFeatureClassDescription annotationFeatureClassDescription = new AnnotationFeatureClassDescription(annotationFeatureClassName,
existingAnnotationFeatureClass.GetDefinition())
IsAutoCreate = true,
IsSymbolIDRequired = false,
IsUpdatedOnShapeChange = true
// Add the creation of the Cities annotation feature class inside Places feature dataset
schemaBuilder.Create(new FeatureDatasetDescription(featureDatasetToken),
annotationFeatureClassDescription);
// Execute the DDL
bool success = schemaBuilder.Build();
// Inspect error messages
if (!success)
IReadOnlyList<string> errorMessages = schemaBuilder.ErrorMessages;
//etc.
System.Object
ArcGIS.Core.Data.DDL.Description
ArcGIS.Core.Data.DDL.TableDescription
ArcGIS.Core.Data.DDL.FeatureClassDescription
ArcGIS.Core.Data.DDL.AnnotationFeatureClassDescription
