ArcGIS.Core.Data.DDL Namespace / SchemaBuilder Class / Create Method / Create(IndexDescription) Method
Indicates the ArcGIS.Core.Data.Index to be created.
Example
    Enqueue the create operation on the object referred to by the IndexDescription. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overloads Sub Create( _
       ByVal indexDescription As IndexDescription _
    public void Create(
       IndexDescription indexDescription
    Parameters
    indexDescription
    Exceptions
    ExceptionDescription
    indexDescription is null.
    Memory ArcGIS.Core.Data.Geodatabase does not support indexes.
    Attribute indexes must be ascending on KnowledgeGraphs
    User defined spatial indexes cannot be added to a knowledge graph
    Remarks
    Attribute indexes being added to a knowledge graph dataset must be ascending or a System.InvalidOperationException will be thrown.
    User-defined spatial indexes cannot be added to a knowledge graph dataset. The system automatically creates the spatial index(es) when the dataset is created.
    Example
    Creating a table with index from scratch
      // Must be called within QueuedTask.Run
      void CreatingTableWithIndex(SchemaBuilder schemaBuilder)
        FieldDescription nameFieldDescription = FieldDescription.CreateStringField("Name", 50);
        FieldDescription addressFieldDescription = FieldDescription.CreateStringField("Address", 200);
        // Creating a feature class, 'Buildings' with two fields
        TableDescription tableDescription = new TableDescription("Buildings",
          new List<FieldDescription>() { nameFieldDescription, addressFieldDescription });
        // Enqueue DDL operation to create a table
        TableToken tableToken = schemaBuilder.Create(tableDescription);
        // Creating an attribute index named as 'Idx'
        AttributeIndexDescription attributeIndexDescription = new AttributeIndexDescription("Idx", new TableDescription(tableToken),
          new List<string> { nameFieldDescription.Name, addressFieldDescription.Name });
        // Enqueue DDL operation to create an attribute index
        schemaBuilder.Create(attributeIndexDescription);
        // Execute build indexes operation
        bool isBuildSuccess = schemaBuilder.Build();
    Adding indexes in pre-existing dataset
      void AddingIndexes(SchemaBuilder schemaBuilder, FeatureClassDefinition featureClassDefinition)
        // Field names to add in the attribute index
        string fieldName = featureClassDefinition.GetFields().First(f => f.AliasName.Contains("Name")).Name;
        string fieldAddress = featureClassDefinition.GetFields().First(f => f.AliasName.Contains("Address")).Name;
        // Creating an attribute index with index name 'Idx' and two participating fields' name
          new TableDescription(featureClassDefinition), new List<string> { fieldName, fieldAddress });
        // Enqueue DDL operation for an attribute index creation
        // Creating the spatial index
        SpatialIndexDescription spatialIndexDescription = new SpatialIndexDescription(new FeatureClassDescription(featureClassDefinition));
        // Enqueue DDL operation for the spatial index creation
        schemaBuilder.Create(spatialIndexDescription);
        if (!isBuildSuccess)
          IReadOnlyList<string> errors = schemaBuilder.ErrorMessages;
          // Iterate and handle errors
    Creating table with subtypes
      void CreateTableWithSubtypes(SchemaBuilder schemaBuilder)
        // Creating a 'Building' table with the subtype field 'BuildingType'
        FieldDescription buildingType = new FieldDescription("BuildingType", FieldType.Integer);
        FieldDescription buildingName = new FieldDescription("Name", FieldType.String);
        TableDescription tableDescription = new TableDescription("Building", new List<FieldDescription> { buildingName, buildingType });
        // Add the building type subtype with three subtypes - Business, Marketing, Security
        tableDescription.SubtypeFieldDescription = new SubtypeFieldDescription(buildingType.Name,
          new Dictionary<int, string> { { 1, "Business" }, { 2, "Marketing" }, { 3, "Security" } })
          DefaultSubtypeCode = 3 // Assigning 'Security' building type as the default subtype
    Creating relationship class
      void CreateRelationshipWithRelationshipRules(SchemaBuilder schemaBuilder)
        // Creating a 'BuildingType' table with two fields - BuildingType and BuildingTypeDescription
        FieldDescription buildingType = FieldDescription.CreateIntegerField("BuildingType");
        FieldDescription buildingTypeeDescription = FieldDescription.CreateStringField("BuildingTypeDescription", 100);
        TableDescription buildingTypeDescription = new TableDescription("BuildingType",
          new List<FieldDescription>() { buildingType, buildingTypeeDescription });
        TableToken buildingtypeToken = schemaBuilder.Create(buildingTypeDescription);
        // Creating a 'Building' feature class with three fields - BuildingId, Address, and BuildingType
        FieldDescription buildingId = FieldDescription.CreateIntegerField("BuildingId");
        FieldDescription buildingAddress = FieldDescription.CreateStringField("Address", 100);
        FieldDescription usageSubType = FieldDescription.CreateIntegerField("UsageSubtype");
        FeatureClassDescription featureClassDescription = new FeatureClassDescription("Building",
          new List<FieldDescription> { buildingId, buildingAddress, buildingType, usageSubType },
          new ShapeDescription(GeometryType.Polygon, SpatialReferences.WGS84));
        // Set subtype details (optional)
        featureClassDescription.SubtypeFieldDescription = new SubtypeFieldDescription(usageSubType.Name,
          new Dictionary<int, string> { { 1, "Marketing" }, { 2, "Utility" } });
        FeatureClassToken buildingToken = schemaBuilder.Create(featureClassDescription);
        // Creating a 1:M relationship between the 'Building' feature class and 'BuildingType' table
        RelationshipClassDescription relationshipClassDescription = new RelationshipClassDescription(
          "BuildingToBuildingType", new FeatureClassDescription(buildingToken), new TableDescription(buildingtypeToken),
          RelationshipCardinality.OneToMany, buildingType.Name, buildingType.Name)
          RelationshipType = RelationshipType.Composite
        // Adding relationship rules for the 'Marketing' subtype
        relationshipClassDescription.RelationshipRuleDescriptions.Add(new RelationshipRuleDescription(1, null));
        schemaBuilder.Create(relationshipClassDescription);
    Creating attributed relationship class
      void CreateAttributedRelationship(SchemaBuilder schemaBuilder)
          new List<FieldDescription> { buildingId, buildingAddress, buildingType },
        // Creating M:M relationship between the 'Building' feature class and 'BuildingType' table
        AttributedRelationshipClassDescription attributedRelationshipClassDescription =
          new AttributedRelationshipClassDescription("BuildingToBuildingType",
            new TableDescription(buildingtypeToken), RelationshipCardinality.ManyToMany, "OBJECTID", "BuildingID",
            "OBJECTID", "BuildingTypeID");
        // Adding optional attribute field in the intermediate table - 'OwnershipPercentage' field
        attributedRelationshipClassDescription.FieldDescriptions.Add(FieldDescription.CreateIntegerField("OwnershipPercentage"));
        schemaBuilder.Create(attributedRelationshipClassDescription);
    Create Attribute Indexes on KG Schemas with SchemaBuilder
      await QueuedTask.Run(() =>
        using (var kg = GetKnowledgeGraph(url))
          var entity_name = "PhoneCall";
          //indexes are managed on the GDB objects...
          var entity_table_def = kg.GetDefinition<TableDefinition>(entity_name);
          var entity_table_desc = new TableDescription(entity_table_def);
          var entity_table_flds = entity_table_def.GetFields();
          AttributeIndexDescription attr_index1 = null;
          AttributeIndexDescription attr_index2 = null;
          foreach (var fld in entity_table_flds)
            //index the first string field
            if (fld.FieldType == FieldType.String && attr_index1 == null)
              if (fld.Name == "ESRI__ID")//special case
                continue;
              //Index _must_ be ascending for KG
              attr_index1 = new AttributeIndexDescription(
                "Index1", entity_table_desc, new List<string> { fld.Name })
                IsAscending = true
            //index the first numeric field (if there is one)
            if ((fld.FieldType == FieldType.BigInteger ||
                 fld.FieldType == FieldType.Integer ||
                 fld.FieldType == FieldType.Single ||
                 fld.FieldType == FieldType.SmallInteger ||
                 fld.FieldType == FieldType.Double) && attr_index2 == null)
              attr_index2 = new AttributeIndexDescription(
                "Index2", entity_table_desc, new List<string> { fld.Name })
                IsAscending = true,
                IsUnique = true //optional - unique if all values are to be unique in the index
            if (attr_index1 != null && attr_index2 != null) break;
          if (attr_index1 == null && attr_index2 == null)
            return; //nothing to index
          //Run the schema builder
          try
            SchemaBuilder sb = new(kg);
            if (attr_index1 != null)
              sb.Create(attr_index1);
            if (attr_index2 != null)
              sb.Create(attr_index2);
            if (!kg.ApplySchemaEdits(sb))
              var err_msg = string.Join(",", sb.ErrorMessages.ToArray());
              System.Diagnostics.Debug.WriteLine($"Create index error: {err_msg}");
          catch (Exception ex)
            System.Diagnostics.Debug.WriteLine(ex.ToString());
    Requirements
    ArcGIS Pro version: 3.1 or higher.
