ArcGIS.Core.Data.DDL Namespace / SchemaBuilder Class / Create Method / Create(KnowledgeGraphTypeDescription) Method
Example
    Enqueue the create operation on the object referred to by the ArcGIS.Core.Data.DDL.Knowledge.KnowledgeGraphTypeDescription. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Exceptions
    ExceptionDescription
    namedObjectTypeDescription is null
    A KnowledgeGraph must be set as the datasource for this operation
    Remarks
    An object id and global id property are always added to new named object types whether explicitly specified in the namedObjectTypeDescription or not. In addition, the required origin id and destination id fields are also automatically added to all new relationship named object types (also whether explicitly specified or not). A shape description is optional. However, if the namedObjectTypeDescription includes a shape description then its spatial reference must match the spatial reference of the knowledge graph datasource (in which it is being created).
    Example
    Creating a table with index from scratch
      // Must be called within QueuedTask.Run
      void CreatingTableWithIndex(SchemaBuilder schemaBuilder)
        FieldDescription nameFieldDescription = FieldDescription.CreateStringField("Name", 50);
        FieldDescription addressFieldDescription = FieldDescription.CreateStringField("Address", 200);
        // Creating a feature class, 'Buildings' with two fields
        TableDescription tableDescription = new TableDescription("Buildings",
          new List<FieldDescription>() { nameFieldDescription, addressFieldDescription });
        // Enqueue DDL operation to create a table
        TableToken tableToken = schemaBuilder.Create(tableDescription);
        // Creating an attribute index named as 'Idx'
        AttributeIndexDescription attributeIndexDescription = new AttributeIndexDescription("Idx", new TableDescription(tableToken),
          new List<string> { nameFieldDescription.Name, addressFieldDescription.Name });
        // Enqueue DDL operation to create an attribute index
        schemaBuilder.Create(attributeIndexDescription);
        // Execute build indexes operation
        bool isBuildSuccess = schemaBuilder.Build();
    Adding indexes in pre-existing dataset
      void AddingIndexes(SchemaBuilder schemaBuilder, FeatureClassDefinition featureClassDefinition)
        // Field names to add in the attribute index
        string fieldName = featureClassDefinition.GetFields().First(f => f.AliasName.Contains("Name")).Name;
        string fieldAddress = featureClassDefinition.GetFields().First(f => f.AliasName.Contains("Address")).Name;
        // Creating an attribute index with index name 'Idx' and two participating fields' name
          new TableDescription(featureClassDefinition), new List<string> { fieldName, fieldAddress });
        // Enqueue DDL operation for an attribute index creation
        // Creating the spatial index
        SpatialIndexDescription spatialIndexDescription = new SpatialIndexDescription(new FeatureClassDescription(featureClassDefinition));
        // Enqueue DDL operation for the spatial index creation
        schemaBuilder.Create(spatialIndexDescription);
        if (!isBuildSuccess)
          IReadOnlyList<string> errors = schemaBuilder.ErrorMessages;
          // Iterate and handle errors
    Creating table with subtypes
      void CreateTableWithSubtypes(SchemaBuilder schemaBuilder)
        // Creating a 'Building' table with the subtype field 'BuildingType'
        FieldDescription buildingType = new FieldDescription("BuildingType", FieldType.Integer);
        FieldDescription buildingName = new FieldDescription("Name", FieldType.String);
        TableDescription tableDescription = new TableDescription("Building", new List<FieldDescription> { buildingName, buildingType });
        // Add the building type subtype with three subtypes - Business, Marketing, Security
        tableDescription.SubtypeFieldDescription = new SubtypeFieldDescription(buildingType.Name,
          new Dictionary<int, string> { { 1, "Business" }, { 2, "Marketing" }, { 3, "Security" } })
          DefaultSubtypeCode = 3 // Assigning 'Security' building type as the default subtype
    Creating relationship class
      void CreateRelationshipWithRelationshipRules(SchemaBuilder schemaBuilder)
        // Creating a 'BuildingType' table with two fields - BuildingType and BuildingTypeDescription
        FieldDescription buildingType = FieldDescription.CreateIntegerField("BuildingType");
        FieldDescription buildingTypeeDescription = FieldDescription.CreateStringField("BuildingTypeDescription", 100);
        TableDescription buildingTypeDescription = new TableDescription("BuildingType",
          new List<FieldDescription>() { buildingType, buildingTypeeDescription });
        TableToken buildingtypeToken = schemaBuilder.Create(buildingTypeDescription);
        // Creating a 'Building' feature class with three fields - BuildingId, Address, and BuildingType
        FieldDescription buildingId = FieldDescription.CreateIntegerField("BuildingId");
        FieldDescription buildingAddress = FieldDescription.CreateStringField("Address", 100);
        FieldDescription usageSubType = FieldDescription.CreateIntegerField("UsageSubtype");
        FeatureClassDescription featureClassDescription = new FeatureClassDescription("Building",
          new List<FieldDescription> { buildingId, buildingAddress, buildingType, usageSubType },
          new ShapeDescription(GeometryType.Polygon, SpatialReferences.WGS84));
        // Set subtype details (optional)
        featureClassDescription.SubtypeFieldDescription = new SubtypeFieldDescription(usageSubType.Name,
          new Dictionary<int, string> { { 1, "Marketing" }, { 2, "Utility" } });
        FeatureClassToken buildingToken = schemaBuilder.Create(featureClassDescription);
        // Creating a 1:M relationship between the 'Building' feature class and 'BuildingType' table
        RelationshipClassDescription relationshipClassDescription = new RelationshipClassDescription(
          "BuildingToBuildingType", new FeatureClassDescription(buildingToken), new TableDescription(buildingtypeToken),
          RelationshipCardinality.OneToMany, buildingType.Name, buildingType.Name)
          RelationshipType = RelationshipType.Composite
        // Adding relationship rules for the 'Marketing' subtype
        relationshipClassDescription.RelationshipRuleDescriptions.Add(new RelationshipRuleDescription(1, null));
        schemaBuilder.Create(relationshipClassDescription);
    Creating attributed relationship class
      void CreateAttributedRelationship(SchemaBuilder schemaBuilder)
          new List<FieldDescription> { buildingId, buildingAddress, buildingType },
        // Creating M:M relationship between the 'Building' feature class and 'BuildingType' table
        AttributedRelationshipClassDescription attributedRelationshipClassDescription =
          new AttributedRelationshipClassDescription("BuildingToBuildingType",
            new TableDescription(buildingtypeToken), RelationshipCardinality.ManyToMany, "OBJECTID", "BuildingID",
            "OBJECTID", "BuildingTypeID");
        // Adding optional attribute field in the intermediate table - 'OwnershipPercentage' field
        attributedRelationshipClassDescription.FieldDescriptions.Add(FieldDescription.CreateIntegerField("OwnershipPercentage"));
        schemaBuilder.Create(attributedRelationshipClassDescription);
    Create Entity and Relationship Types with SchemaBuilder
            await QueuedTask.Run(() =>
      using (var kg = GetKnowledgeGraph(url))
        var entity_name = "PhoneCall";
        var relate_name = "WhoCalledWho";
        //Entity Fields
        var descs1 =
            new List<KnowledgeGraphPropertyDescription>();
        descs1.Add(
          new KnowledgeGraphPropertyDescription("PhoneOwner", FieldType.String));
        descs1.Add(
          new KnowledgeGraphPropertyDescription("PhoneNumber", FieldType.String));
        descs1.Add(
          new KnowledgeGraphPropertyDescription("LocationID", FieldType.BigInteger));
        descs1.Add(
          new KnowledgeGraphPropertyDescription("DateAndTime", FieldType.Date));
        //Relate Fields
        var descs2 =
        descs2.Add(
          new KnowledgeGraphPropertyDescription("Foo", FieldType.String));
        descs2.Add(
          new KnowledgeGraphPropertyDescription("Bar", FieldType.String));
        var includeShape = true;//change to false to omit the shape column
        var hasZ = false;
        var hasM = false;
        KnowledgeGraphEntityTypeDescription entityDesc = null;
        KnowledgeGraphRelationshipTypeDescription relateDesc = null;
        if (includeShape)
          var sr = kg.GetSpatialReference();
          var shp_desc = new ShapeDescription(GeometryType.Point, sr)
            HasM = hasM,
            HasZ = hasZ
          entityDesc = new KnowledgeGraphEntityTypeDescription(
            entity_name, descs1, shp_desc);
          relateDesc = new KnowledgeGraphRelationshipTypeDescription(
            relate_name, descs2, shp_desc);
        else
            entity_name, descs1);
            relate_name, descs2);
        //Run the schema builder
        try
          SchemaBuilder sb = new(kg);
          sb.Create(entityDesc);
          sb.Create(relateDesc);
          //Use the KnowledgeGraph extension method 'ApplySchemaEdits(...)'
          //to refresh the Pro UI
          if (!kg.ApplySchemaEdits(sb))
            var err_msg = string.Join(",", sb.ErrorMessages.ToArray());
            System.Diagnostics.Debug.WriteLine($"Entity/Relate Create error: {err_msg}");
        catch (Exception ex)
          System.Diagnostics.Debug.WriteLine(ex.ToString());
    Requirements
    ArcGIS Pro version: 3.4 or higher.
