ArcGIS.Core.Data.DDL Namespace / SchemaBuilder Class / Create Method / Create(FeatureDatasetDescription,AnnotationFeatureClassDescription) Method
Indicates the ArcGIS.Core.Data.FeatureDataset where the ArcGIS.Core.Data.Mapping.AnnotationFeatureClass will be created.
Indicates the ArcGIS.Core.Data.Mapping.AnnotationFeatureClass to be created.
Example
    Enqueue the create operation on the object referred to by the AnnotationFeatureClassDescription. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Exceptions
    ExceptionDescription
    The ArcGIS.Core.Geometry.SpatialReference of the featureDatasetDescription and the annotationFeatureClassDescription do not match.
    -or-
    The total path length for the ArcGIS.Core.Data.Mapping.AnnotationFeatureClass to be created must be less than 252 characters.
    -or-
    The annotation symbols are invalid.
    featureDatasetDescription and/or annotationFeatureClassDescription is null.
    Memory ArcGIS.Core.Data.Geodatabase does not support feature datasets.
    Remarks
    Example
    Creating an annotation feature class inside feature dataset
      // Must be called within QueuedTask.Run
      void CreateAnnotationFeatureClassUsingExistingAnnotationFeatureClassInDataset(
        Geodatabase geodatabase)
        // Create a Cities annotation feature class inside Places feature dataset using existing annotation feature class
        // Feature dataset name
        string featureDatasetName = "Places";
        // Annotation feature class name
        string annotationFeatureClassName = "CitiesAnnotation";
        // Create a SchemaBuilder object
        SchemaBuilder schemaBuilder = new SchemaBuilder(geodatabase);
        // Open existing annotation feature class name
        using (AnnotationFeatureClass existingAnnotationFeatureClass = geodatabase.OpenDataset<AnnotationFeatureClass>("ExistingAnnotationFeatureClass"))
          // Create Feature dataset description
          FeatureDatasetDescription featureDatasetDescription = new FeatureDatasetDescription(featureDatasetName, existingAnnotationFeatureClass.GetDefinition().GetSpatialReference());
          // Add the creation of the Places dataset to DDL task
          FeatureDatasetToken featureDatasetToken = schemaBuilder.Create(featureDatasetDescription);
          // Create an annotation feature class description using existing annotation feature class
          AnnotationFeatureClassDescription annotationFeatureClassDescription = new AnnotationFeatureClassDescription(annotationFeatureClassName,
              existingAnnotationFeatureClass.GetDefinition())
            IsAutoCreate = true,
            IsSymbolIDRequired = false,
            IsUpdatedOnShapeChange = true
          // Add the creation of the Cities annotation feature class inside Places feature dataset
          schemaBuilder.Create(new FeatureDatasetDescription(featureDatasetToken),
            annotationFeatureClassDescription);
          // Execute the DDL
          bool success = schemaBuilder.Build();
          // Inspect error messages
          if (!success)
            IReadOnlyList<string> errorMessages = schemaBuilder.ErrorMessages;
            //etc.
    Creating a table with index from scratch
      void CreatingTableWithIndex(SchemaBuilder schemaBuilder)
        FieldDescription nameFieldDescription = FieldDescription.CreateStringField("Name", 50);
        FieldDescription addressFieldDescription = FieldDescription.CreateStringField("Address", 200);
        // Creating a feature class, 'Buildings' with two fields
        TableDescription tableDescription = new TableDescription("Buildings",
          new List<FieldDescription>() { nameFieldDescription, addressFieldDescription });
        // Enqueue DDL operation to create a table
        TableToken tableToken = schemaBuilder.Create(tableDescription);
        // Creating an attribute index named as 'Idx'
        AttributeIndexDescription attributeIndexDescription = new AttributeIndexDescription("Idx", new TableDescription(tableToken),
          new List<string> { nameFieldDescription.Name, addressFieldDescription.Name });
        // Enqueue DDL operation to create an attribute index
        schemaBuilder.Create(attributeIndexDescription);
        // Execute build indexes operation
        bool isBuildSuccess = schemaBuilder.Build();
    Adding indexes in pre-existing dataset
      void AddingIndexes(SchemaBuilder schemaBuilder, FeatureClassDefinition featureClassDefinition)
        // Field names to add in the attribute index
        string fieldName = featureClassDefinition.GetFields().First(f => f.AliasName.Contains("Name")).Name;
        string fieldAddress = featureClassDefinition.GetFields().First(f => f.AliasName.Contains("Address")).Name;
        // Creating an attribute index with index name 'Idx' and two participating fields' name
          new TableDescription(featureClassDefinition), new List<string> { fieldName, fieldAddress });
        // Enqueue DDL operation for an attribute index creation
        // Creating the spatial index
        SpatialIndexDescription spatialIndexDescription = new SpatialIndexDescription(new FeatureClassDescription(featureClassDefinition));
        // Enqueue DDL operation for the spatial index creation
        schemaBuilder.Create(spatialIndexDescription);
        if (!isBuildSuccess)
          IReadOnlyList<string> errors = schemaBuilder.ErrorMessages;
          // Iterate and handle errors
    Creating table with subtypes
      void CreateTableWithSubtypes(SchemaBuilder schemaBuilder)
        // Creating a 'Building' table with the subtype field 'BuildingType'
        FieldDescription buildingType = new FieldDescription("BuildingType", FieldType.Integer);
        FieldDescription buildingName = new FieldDescription("Name", FieldType.String);
        TableDescription tableDescription = new TableDescription("Building", new List<FieldDescription> { buildingName, buildingType });
        // Add the building type subtype with three subtypes - Business, Marketing, Security
        tableDescription.SubtypeFieldDescription = new SubtypeFieldDescription(buildingType.Name,
          new Dictionary<int, string> { { 1, "Business" }, { 2, "Marketing" }, { 3, "Security" } })
          DefaultSubtypeCode = 3 // Assigning 'Security' building type as the default subtype
    Creating relationship class
      void CreateRelationshipWithRelationshipRules(SchemaBuilder schemaBuilder)
        // Creating a 'BuildingType' table with two fields - BuildingType and BuildingTypeDescription
        FieldDescription buildingType = FieldDescription.CreateIntegerField("BuildingType");
        FieldDescription buildingTypeeDescription = FieldDescription.CreateStringField("BuildingTypeDescription", 100);
        TableDescription buildingTypeDescription = new TableDescription("BuildingType",
          new List<FieldDescription>() { buildingType, buildingTypeeDescription });
        TableToken buildingtypeToken = schemaBuilder.Create(buildingTypeDescription);
        // Creating a 'Building' feature class with three fields - BuildingId, Address, and BuildingType
        FieldDescription buildingId = FieldDescription.CreateIntegerField("BuildingId");
        FieldDescription buildingAddress = FieldDescription.CreateStringField("Address", 100);
        FieldDescription usageSubType = FieldDescription.CreateIntegerField("UsageSubtype");
        FeatureClassDescription featureClassDescription = new FeatureClassDescription("Building",
          new List<FieldDescription> { buildingId, buildingAddress, buildingType, usageSubType },
          new ShapeDescription(GeometryType.Polygon, SpatialReferences.WGS84));
        // Set subtype details (optional)
        featureClassDescription.SubtypeFieldDescription = new SubtypeFieldDescription(usageSubType.Name,
          new Dictionary<int, string> { { 1, "Marketing" }, { 2, "Utility" } });
        FeatureClassToken buildingToken = schemaBuilder.Create(featureClassDescription);
        // Creating a 1:M relationship between the 'Building' feature class and 'BuildingType' table
        RelationshipClassDescription relationshipClassDescription = new RelationshipClassDescription(
          "BuildingToBuildingType", new FeatureClassDescription(buildingToken), new TableDescription(buildingtypeToken),
          RelationshipCardinality.OneToMany, buildingType.Name, buildingType.Name)
          RelationshipType = RelationshipType.Composite
        // Adding relationship rules for the 'Marketing' subtype
        relationshipClassDescription.RelationshipRuleDescriptions.Add(new RelationshipRuleDescription(1, null));
        schemaBuilder.Create(relationshipClassDescription);
    Creating attributed relationship class
      void CreateAttributedRelationship(SchemaBuilder schemaBuilder)
          new List<FieldDescription> { buildingId, buildingAddress, buildingType },
        // Creating M:M relationship between the 'Building' feature class and 'BuildingType' table
        AttributedRelationshipClassDescription attributedRelationshipClassDescription =
          new AttributedRelationshipClassDescription("BuildingToBuildingType",
            new TableDescription(buildingtypeToken), RelationshipCardinality.ManyToMany, "OBJECTID", "BuildingID",
            "OBJECTID", "BuildingTypeID");
        // Adding optional attribute field in the intermediate table - 'OwnershipPercentage' field
        attributedRelationshipClassDescription.FieldDescriptions.Add(FieldDescription.CreateIntegerField("OwnershipPercentage"));
        schemaBuilder.Create(attributedRelationshipClassDescription);
    Requirements
