ArcGIS.Core.Geometry Namespace / CompositeHVDatumTransformation Class / Create Method / Create(IEnumerable<HVDatumTransformation>) Method
The list of hv datum transformations to add to a CompositeHVDatumTransformation.
Example
    Creates a new CompositeHVDatumTransformation instance that contains the list of HVDatumTransformation instances.
    Syntax
    Parameters
    hvTransformations
    Return Value
    A new CompositeHVDatumTransformation that contains the list of hv datum transformations.
    Exceptions
    ExceptionDescription
    The hvTransformations list is null or empty.
    Example
    Create Composite HV Datum Transformation
      HVDatumTransformation hv1 = HVDatumTransformation.Create(108034);
      HVDatumTransformation hv2 = HVDatumTransformation.Create(108033, false);
      List<HVDatumTransformation> hvs = new List<HVDatumTransformation>() { hv1, hv2 };
      // create from enumeration
      CompositeHVDatumTransformation compositehv =
                      CompositeHVDatumTransformation.Create(hvs);
      int count = compositehv.Count;      // count = 2
      List<HVDatumTransformation> transforms =
                     compositehv.Transformations as List<HVDatumTransformation>;
      HVDatumTransformation tranform = transforms[0];
      // transform.Wkid = 108034
      // get inverse
      CompositeHVDatumTransformation inverse_compositehv =
             compositehv.GetInverse() as CompositeHVDatumTransformation;
      // create from xml
      string xml = compositehv.ToXml();
      var xml_compositehv = CompositeHVDatumTransformation.CreateFromXml(xml);
      // create from json
      string json = compositehv.ToJson();
      CompositeHVDatumTransformation json_compositehv =
          DatumTransformation.CreateFromJson(json) as CompositeHVDatumTransformation;
    Requirements
