ArcGIS.Core.Geometry Namespace / HVDatumTransformation Class / Create Method / Create(Int32,Boolean) Method
The well-known ID of the hv datum transformation to be created.
(Optional) Default is true. If false, the created transformation is inverted.
Example
    Creates a new HVDatumTransformation instance from a well-known ID.
    Syntax
    Public Overloads Shared Function Create( _
       ByVal wkid As Integer, _
       Optional ByVal transformForward As Boolean _
    ) As HVDatumTransformation
    Parameters
    wkid
    transformForward
    Exceptions
    ExceptionDescription
    The wkid is invalid.
    Example
    Create HV Datum Transformation
      // Create from wkid
      HVDatumTransformation hv110018 = HVDatumTransformation.Create(110018);
      int wkid = hv110018.Wkid;
      bool isForward = hv110018.IsForward;    // isForward = true
      string name = hv110018.Name;            // Name = WGS_1984_To_WGS_1984_EGM2008_1x1_Height
      // Create from wkt
      string wkt = hv110018.Wkt;
      HVDatumTransformation hv110018FromWkt = HVDatumTransformation.Create(wkt);
      // Get the inverse
      HVDatumTransformation hv110018Inverse =
         hv110018.GetInverse() as HVDatumTransformation;
      // hv110018Inverse.IsForward = false
    Requirements
