ArcGIS.Core.Geometry Namespace / HVDatumTransformation Class / Wkid Property
Example
    Wkid Property (HVDatumTransformation)
    Gets the well-known ID of this horizontal/vertical transformation.
    Syntax
    Public ReadOnly Property Wkid As Integer
    public int Wkid {get;}
    Example
    Create HV Datum Transformation
      // Create from wkid
      HVDatumTransformation hv110018 = HVDatumTransformation.Create(110018);
      int wkid = hv110018.Wkid;
      bool isForward = hv110018.IsForward;    // isForward = true
      string name = hv110018.Name;            // Name = WGS_1984_To_WGS_1984_EGM2008_1x1_Height
      // Create from wkt
      string wkt = hv110018.Wkt;
      HVDatumTransformation hv110018FromWkt = HVDatumTransformation.Create(wkt);
      // Get the inverse
      HVDatumTransformation hv110018Inverse =
         hv110018.GetInverse() as HVDatumTransformation;
      // hv110018Inverse.IsForward = false
    Requirements
