ArcGIS.Core.Data Namespace / Geodatabase Class / Evaluate Method
Represents a query involving one or more tables from the same geodatabase.
If set to true, all the entries in RowCursor will reference the most current row returned by RowCursor.Current. To ensure all the entries in RowCursor remain unique, set useRecyclingCursor to false.
Example
    Evaluate Method (Geodatabase)
    Evaluates the query and return a RowCursor.
    Syntax
    Public Function Evaluate( _
       ByVal queryDef As QueryDef, _
       Optional ByVal useRecyclingCursor As Boolean _
    ) As RowCursor
    Parameters
    queryDef
    useRecyclingCursor
    Return Value
    A RowCursor that encapsulates the retrieved rows of type Row or Feature.
    Exceptions
    ExceptionDescription
    No valid geodatabase has been opened prior to invoking this operation.
    queryDef is null.
    A geodatabase-related exception has occurred.
    Remarks
    The rows retrieved from the RowCursor may be of type Row or Feature. If there exists a feature class (i.e., spatial table) specified in the QueryDef.Tables's comma-delimited string AND the QueryDef.SubFields contains either the default value (i.e., "*") or the spatial field name (e.g., "SHAPE" of type FieldType.Geometry), then the retrieved rows are of type Feature. Otherwise, they are of type Row.
    Example
    Evaluating a QueryDef on a single table
      await QueuedTask.Run(() =>
        using (Geodatabase geodatabase = new Geodatabase(new DatabaseConnectionFile(new Uri("path\\to\\sde\\file"))))
          QueryDef adaCompilantParksQueryDef = new QueryDef
            Tables = "Park",
            WhereClause = "ADACOMPLY = 'Yes'",
          using (RowCursor rowCursor = geodatabase.Evaluate(adaCompilantParksQueryDef, false))
            while (rowCursor.MoveNext())
              using (Row row = rowCursor.Current)
                Feature feature = row as Feature;
                Geometry shape = feature.GetShape();
                String type = Convert.ToString(row["ADACOMPLY"]); // will be "Yes" for each row.
                try
                  Table table = row.GetTable(); // Will always throw exception.
                catch (NotSupportedException exception)
                  // Handle not supported exception.
    Evaluating a QueryDef on a Join using WHERE Clause
          QueryDef municipalEmergencyFacilitiesQueryDef = new QueryDef
            SubFields = "EmergencyFacility.OBJECTID, EmergencyFacility.Shape, EmergencyFacility.FACILITYID, FacilitySite.FACILITYID, FacilitySite.FCODE",
            Tables = "EmergencyFacility, FacilitySite",
            WhereClause = "EmergencyFacility.FACNAME = FacilitySite.NAME AND EmergencyFacility.JURISDICT = 'Municipal'",
          using (RowCursor rowCursor = geodatabase.Evaluate(municipalEmergencyFacilitiesQueryDef, false))
                long objectID = Convert.ToInt64(row["EmergencyFacility.OBJECTID"]);
                String featureCode = Convert.ToString(row["FacilitySite.FCODE"]);
                IReadOnlyList<Field>
                  fields = feature.GetFields(); //Contains one ArcGIS.Core.Data.Field objects for every subfield
    Evaluating a QueryDef on a OUTER JOIN
          QueryDef queryDefWithLeftOuterJoin = new QueryDef
            Tables = "CommunityAddress LEFT OUTER JOIN MunicipalBoundary on CommunityAddress.Municipality = MunicipalBoundary.Name",
            SubFields = "CommunityAddress.OBJECTID, CommunityAddress.Shape, CommunityAddress.SITEADDID, CommunityAddress.ADDRNUM, CommunityAddress.FULLNAME, CommunityAddress.FULLADDR, CommunityAddress.MUNICIPALITY, MunicipalBoundary.Name, MunicipalBoundary.MUNITYP, MunicipalBoundary.LOCALFIPS",
          using (RowCursor rowCursor = geodatabase.Evaluate(queryDefWithLeftOuterJoin, false))
                int siteAddressId = Convert.ToInt32(row["CommunityAddress.SITEADDID"]);
                String stateName = Convert.ToString(row["MunicipalBoundary.name"]);
    Evaluating a QueryDef on a INNER join
          QueryDef queryDef = new QueryDef()
            Tables = "People INNER JOIN States ON People.FK_STATE_ID = States.OBJECTID",
            SubFields = "People.OBJECTID, People.First_Name, People.Last_Name, People.City, States.State_Name"
          using (RowCursor cursor = geodatabase.Evaluate(queryDef))
            while (cursor.MoveNext())
              using (Row row = cursor.Current)
                // Handle row
    Evaluating a QueryDef on a nested - INNER and OUTER join
            Tables = "((People INNER JOIN States ON People.FK_STATE_ID = States.OBJECTID) LEFT OUTER JOIN Homes ON People.OBJECTID = Homes.FK_People_ID)",
            SubFields = "People.OBJECTID, People.First_Name, People.Last_Name, States.State_Name, Homes.Address"
          using (RowCursor cursor = geodatabase.Evaluate(queryDef, false))
                // Handle row
    Requirements
