ArcGIS.Core.Data Namespace / Feature Class
Members Example
    Feature Class
    Represents a feature in a FeatureClass.
    Object Model
    Feature ClassGeometry ClassFeatureClass Class
    Syntax
    Public Class Feature
       Inherits Row
       Implements System.IDisposable
    public class Feature : Row, System.IDisposable
    Example
    Reading a Blob field
      // Must be called within QueuedTask.Run
      void ReadBlobField(Table table, QueryFilter queryFilter, string blobFieldName)
        const string imageFileBaseName = "C:\\path\\to\\image\\directory\\Image";
        // For each row that satisfies the search criteria, write the blob field out to an image file
        using (RowCursor rowCursor = table.Search(queryFilter))
          int fileCount = 0;
          while (rowCursor.MoveNext())
            using (Row row = rowCursor.Current)
              // Read the blob field into a MemoryStream
              MemoryStream memoryStream = row[blobFieldName] as MemoryStream;
              // Create a file
              using (FileStream outputFile = new FileStream(imageFileBaseName + fileCount.ToString(),
                       FileMode.Create, FileAccess.Write))
                // Write the MemoryStream into the file
                memoryStream.WriteTo(outputFile);
    Inheritance Hierarchy
    System.Object
       ArcGIS.Core.CoreObjectsBase
          ArcGIS.Core.Data.Row
             ArcGIS.Core.Data.Feature
                ArcGIS.Core.Data.Mapping.AnnotationFeature
                ArcGIS.Core.Data.Mapping.CatalogDatasetFeature
                ArcGIS.Core.Data.Mapping.DimensionFeature
    Requirements
