ArcGIS.Core.Data Namespace / Feature Class
Properties Methods
    Feature Class Members
    The following tables list the members exposed by Feature.
    Public Properties
     NameDescription
    Public Property Gets the opaque handle to the underlying native object. (Inherited from ArcGIS.Core.CoreObjectsBase)
    Public PropertyOverloaded. Overridden.  Gets and sets the value of a field given its index position. This method must be called on the MCT. Use QueuedTask.Run.
    Top
    Public Methods
     NameDescription
    Public Method Adds a given attachment to a row. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Row)
    Public Method Deletes the row. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Row)
    Public Method Deletes attachment(s) provided by attachmentID that are associated with the row. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Row)
    Public Method (Inherited from ArcGIS.Core.CoreObjectsBase)
    Public Method Gets the index position for a field by name. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Row)
    Public MethodGets a IReadOnlyList of attachments based on the requested attachmentIDs for a given row. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Row)
    Public MethodGets a IReadOnlyList containing the fields of the row. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Row)
    Public MethodGets the global ID in the form of System.Guid associated with the row. If the row does not have a global ID, an empty Guid is returned. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Row)
    Public Method Gets the object ID of the row. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Row)
    Public MethodOverridden.  Gets the original value of a field at the given index. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Gets the geometry of this feature. This method must be called on the MCT. Use QueuedTask.Run.
    Public MethodGets the parent FeatureClass of this feature. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Gets a value indicating whether the value of the field at the given index has changed. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Row)
    Public Method Sets the geometry of this feature. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Splits a polyline or polygon into multiple parts from the provided split geometry location with a system-assigned object ID.
    Public Method Stores the row. This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Row)
    Public Method Updates the properties of an existing attachment fetched using GetAttachment with new values This method must be called on the MCT. Use QueuedTask.Run. (Inherited from ArcGIS.Core.Data.Row)
    Top
