ArcGIS.Core Namespace / CoreObjectsBase Class / Dispose Method / Dispose() Method
Example
    Dispose() Method
    Releases this object's unmanaged resources.
    Syntax
    Public Overloads Sub Dispose()
    public void Dispose()
    Example
    Checking for the existence of a Table
      //Must be called within QueuedTask.Run().
      bool TableExists(Geodatabase geodatabase, string tableName)
        try
          using TableDefinition tableDefinition =
            geodatabase.GetDefinition<TableDefinition>(tableName);
          return true;
        catch
          // GetDefinition throws an exception if the definition doesn't exist
          return false;
    Checking for the existence of a Feature Class
      bool FeatureClassExists(Geodatabase geodatabase, string featureClassName)
        try
          using FeatureClassDefinition featureClassDefinition =
            geodatabase.GetDefinition<FeatureClassDefinition>(featureClassName);
          return true;
        catch
          return false;
    Requirements
