ArcGIS.Core.Data Namespace / Feature Class / Split Method
Location to split a polyline or polygon feature
Example
    Split Method (Feature)
    Splits a polyline or polygon into multiple parts from the provided split geometry location with a system-assigned object ID.
    Syntax
    Parameters
    splitGeometry
    Return Value
    The ObjectIDs of newly created features from the split operation.
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    splitGeometry is invalid (e.g., a null value or an empty).
    Remarks
    A point feature can split a polyline.
    A polyline can split a polygon.
    A line or multipoint cannot split a line; similarly, a polygon cannot split a polygon.
    Example
    Split a feature by geometry
      // Must be called within QueuedTask.Run
      void SplitALineByPoint(FeatureClass lineFeatureClass, MapPoint xPoint)
        using (RowCursor rowCursor =
               lineFeatureClass.Search(new QueryFilter() { ObjectIDs = new List<long>() { 1 } }))
          if (rowCursor.MoveNext())
            using (Feature feature = rowCursor.Current as Feature)
              // ObjectIDs of newly created lines
              IReadOnlyList<long> splits = feature.Split(xPoint);
    Requirements
    ArcGIS Pro version: 3.4 or higher.
