Parameters
- shape
- The geometry of this feature.
| Exception | Description |
| ArcGIS.Core.Geometry.Exceptions.GeometryException | This feature's type of shape (i.e., geometry) is not supported. |
| ArcGIS.Core.Data.Exceptions.GeodatabaseException | A geodatabase-related exception has occurred. |
await QueuedTask.Run(() =>
string message = String.Empty;
bool modificationResult = false;
using (Geodatabase geodatabase = new Geodatabase(new DatabaseConnectionFile(new Uri("path\\to\\sde\\file\\sdefile.sde"))))
using (FeatureClass enterpriseFeatureClass = geodatabase.OpenDataset<FeatureClass>("LocalGovernment.GDB.FacilitySite"))
FeatureClassDefinition facilitySiteDefinition = enterpriseFeatureClass.GetDefinition();
int ownTypeIndex = facilitySiteDefinition.FindField("OWNTYPE");
int areaIndex = facilitySiteDefinition.FindField(facilitySiteDefinition.GetAreaField());
EditOperation editOperation = new EditOperation();
editOperation.Callback(context =>
QueryFilter queryFilter = new QueryFilter
WhereClause = "FCODE = 'Hazardous Materials Facility' AND OWNTYPE = ' '"
using (RowCursor rowCursor = enterpriseFeatureClass.Search(queryFilter, false))
while (rowCursor.MoveNext())
using (Feature feature = (Feature)rowCursor.Current)
// In order to update the Map and/or the attribute table.
// Has to be called before any changes are made to the row
context.Invalidate(feature);
// Transfer all Hazardous Material Facilities to the City.
feature[ownTypeIndex] = "Municipal";
if (Convert.ToDouble(feature[areaIndex]) > 50000)
// Set the Shape of the feature to whatever you need.
List<Coordinate2D> newCoordinates = new List<Coordinate2D>
new Coordinate2D(1021570, 1880583),
new Coordinate2D(1028730, 1880994),
new Coordinate2D(1029718, 1875644),
new Coordinate2D(1021405, 1875397)
feature.SetShape(new PolygonBuilderEx(newCoordinates).ToGeometry());
feature.Store();
// Has to be called after the store too
}, enterpriseFeatureClass);
try
modificationResult = editOperation.Execute();
if (!modificationResult)
message = editOperation.ErrorMessage;
catch (GeodatabaseException exObj)
message = exObj.Message;
if (!string.IsNullOrEmpty(message))
Debug.WriteLine(message);
