ArcGIS.Core.Data Namespace / QueryDef Class / WhereClause Property
Example
    WhereClause Property (QueryDef)
    Gets or sets the where clause used to filter the rows returned.
    Syntax
    Public Property WhereClause As String
    public string WhereClause {get; set;}
    Remarks
    Rows for which the where clause evaluates to True are returned by the filter. Those rows which evaluate to False or Unknown (Null) are not returned.
    Example
    Evaluating a QueryDef on a single table
      await QueuedTask.Run(() =>
        using (Geodatabase geodatabase = new Geodatabase(new DatabaseConnectionFile(new Uri("path\\to\\sde\\file"))))
          QueryDef adaCompilantParksQueryDef = new QueryDef
            Tables = "Park",
            WhereClause = "ADACOMPLY = 'Yes'",
          using (RowCursor rowCursor = geodatabase.Evaluate(adaCompilantParksQueryDef, false))
            while (rowCursor.MoveNext())
              using (Row row = rowCursor.Current)
                Feature feature = row as Feature;
                Geometry shape = feature.GetShape();
                String type = Convert.ToString(row["ADACOMPLY"]); // will be "Yes" for each row.
                try
                  Table table = row.GetTable(); // Will always throw exception.
                catch (NotSupportedException exception)
                  // Handle not supported exception.
    Evaluating a QueryDef on a Join using WHERE Clause
          QueryDef municipalEmergencyFacilitiesQueryDef = new QueryDef
            SubFields = "EmergencyFacility.OBJECTID, EmergencyFacility.Shape, EmergencyFacility.FACILITYID, FacilitySite.FACILITYID, FacilitySite.FCODE",
            Tables = "EmergencyFacility, FacilitySite",
            WhereClause = "EmergencyFacility.FACNAME = FacilitySite.NAME AND EmergencyFacility.JURISDICT = 'Municipal'",
          using (RowCursor rowCursor = geodatabase.Evaluate(municipalEmergencyFacilitiesQueryDef, false))
                long objectID = Convert.ToInt64(row["EmergencyFacility.OBJECTID"]);
                String featureCode = Convert.ToString(row["FacilitySite.FCODE"]);
                IReadOnlyList<Field>
                  fields = feature.GetFields(); //Contains one ArcGIS.Core.Data.Field objects for every subfield
    Requirements
