ArcGIS.Desktop.Mapping Namespace / SymbolFactory Class / GetDictionarySymbol Method
The name of the dictionary to be used.
A dictionary of objects defining the values to be used to build the symbol.
    GetDictionarySymbol Method (SymbolFactory)
    Builds a symbol from a dictionary. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function GetDictionarySymbol( _
       ByVal dictionaryName As String, _
       ByVal values As Dictionary(Of String,Object) _
    ) As CIMSymbol
    Parameters
    dictionaryName
    values
    Return Value
    Exceptions
    ExceptionDescription
    This method must be called within the lambda passed to QueuedTask.Run
    Requirements
