Public Property GraphicFrame As CIMGraphicFrame
public CIMGraphicFrame GraphicFrame {get; set;}
//Apply a background color to the map frame element using the CIM.
//Note: Must be on QueuedTask.Run
//Get the map frame's definition in order to modify the background.
var mapFrameDefn = mapFrame.GetDefinition() as CIMMapFrame;
//Construct the polygon symbol to use to create a background
var polySymbol = SymbolFactory.Instance.ConstructPolygonSymbol(
ColorFactory.Instance.BlueRGB, SimpleFillStyle.Solid);
//Set the background
mapFrameDefn.GraphicFrame.BackgroundSymbol =
polySymbol.MakeSymbolReference();
//Set the map frame definition
mapFrame.SetDefinition(mapFrameDefn);
