ArcGIS.Desktop.Mapping Namespace / UnclassedColorsRendererDefinition Class / ShowNullValues Property
Example
    ShowNullValues Property (UnclassedColorsRendererDefinition)
    Gets or sets whether null values are shown in the renderer.
    Syntax
    public bool ShowNullValues {get; set;}
    Public Property ShowNullValues As Boolean
    Example
    Create an unclassed Renderer
      string colorBrewerSchemesName = "ArcGIS Colors";
      //Get the style project item that contains the color ramps
      //Refer to the Initialize region for an example of how to get a style item
      await QueuedTask.Run(() =>
      CIMPointSymbol pointSym = SymbolFactory.Instance.ConstructPointSymbol(ColorFactory.Instance.GreenRGB, 16.0, SimpleMarkerStyle.Diamond);
      CIMSymbolReference symbolPointTemplate = pointSym.MakeSymbolReference();
      //defining an unclassed renderer with custom upper and lower stops
      //all features with value >= 5,000,000 will be drawn with the upper color from the color ramp
      //all features with value <= 50,000 will be drawn with the lower color from the color ramp
      UnclassedColorsRendererDefinition unclassRndrDef = new UnclassedColorsRendererDefinition
                            ("Population", symbolPointTemplate, colorRamp, "Highest", "Lowest", 5000000, 50000)
        //drawing features with null values with a different symbol
        ShowNullValues = true,
        NullValueLabel = "Unknown"
      // Create a point symbol for null values
      CIMPointSymbol nullSym = SymbolFactory.Instance.ConstructPointSymbol(ColorFactory.Instance.RedRGB, 16.0, SimpleMarkerStyle.Circle);
      unclassRndrDef.NullValueSymbol = nullSym.MakeSymbolReference();
      //Create the unclassed renderer using the definition
      CIMClassBreaksRenderer cbRndr = featureLayer.CreateRenderer(unclassRndrDef) as CIMClassBreaksRenderer;
      //Set the renderer to the feature layer
      featureLayer.SetRenderer(cbRndr);
    Requirements
