//Consult https://github.com/Esri/arcade-expressions/ and
//https://developers.arcgis.com/arcade/ for more examples
//and arcade reference
await QueuedTask.Run(() =>
//construct an expression
var query = @"Count($layer)";//count of features in "layer"
//construct a CIMExpressionInfo
var arcade_expr = new CIMExpressionInfo()
Expression = query.ToString(),
//Return type can be string, numeric, or default
//When set to default, add-in is responsible for determining
//the return type
ReturnType = ExpressionReturnType.Default
//Construct an evaluator
//select the relevant profile - it must support Pro and it must
//contain any profile variables you are using in your expression.
//Consult: https://developers.arcgis.com/arcade/profiles/
using var arcade = ArcadeScriptEngine.Instance.CreateEvaluator(
arcade_expr, ArcadeProfile.Popups);
//Provision values for any profile variables referenced...
//in our case '$layer'
var variables = new List<KeyValuePair<string, object>>() {
new("$layer", featureLayer)
//evaluate the expression
try
var result = arcade.Evaluate(variables).GetResult();
System.Diagnostics.Debug.WriteLine($"Result: {result}");
//handle any exceptions
catch (InvalidProfileVariableException)
//something wrong with the profile variable specified
//TODO...
catch (EvaluationException)
//something wrong with the query evaluation
//TODO...
var query = @"$feature.AreaInAcres * 43560.0";//convert acres to ft 2
//the return type
//we are evaluating the expression against all features
using var rc = featureLayer.Search();
while (rc.MoveNext())
//in our case '$feature'
new("$feature", rc.Current)
//evaluate the expression (per feature in this case)
try
var val = ((double)result).ToString("0.0#");
$"{rc.Current.GetObjectID()} area: {val} ft2");
//TODO...
//TODO...
// GetRenderer from Layer (assumes it is a unique value renderer)
if (featureLayer.GetRenderer() is not CIMUniqueValueRenderer uvRenderer)
// not a unique value renderer, leave
return;
//layer has STATE_NAME field if using the community sample Data\Admin\AdminSample.aprx
string expression = "if ($view.scale > 21000000) { return $feature.STATE_NAME } else { return 'All' }";
CIMExpressionInfo updatedExpressionInfo = new()
Expression = expression,
Title = "Custom" // can be any string used for UI purpose.
//set the renderer's expression
uvRenderer.ValueExpressionInfo = updatedExpressionInfo;
//SetRenderer on Layer
featureLayer.SetRenderer(uvRenderer);
