ArcGIS.Core.Data Namespace / SQLSyntax Class / QualifyColumnName Method
The name of the table. It may be null or an empty string.
The name of the column. It must not be null or an empty string.
Example
    Given a table name and column name, returns its fully qualified name. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public string QualifyColumnName(
       string tableName,
       string columnName
    Public Function QualifyColumnName( _
       ByVal tableName As String, _
       ByVal columnName As String _
    ) As String
    Parameters
    tableName
    columnName
    Return Value
    The fully qualified column name.
    Exceptions
    ExceptionDescription
    columnName is null or an empty string.
    A geodatabase-related exception has occurred.
    Remarks
    Applications should use the QualifyTableName and QualifyColumnName methods to construct fully qualified dataset and column names.
    Example
    Creating a QueryTable using a query which joins two versioned tables in a geodatabase
      await QueuedTask.Run(() =>
        QueryDef queryDef = new QueryDef
          Tables = "CommunityAddress JOIN MunicipalBoundary on CommunityAddress.Municipality = MunicipalBoundary.Name",
          SubFields = "CommunityAddress.OBJECTID, CommunityAddress.Shape, CommunityAddress.SITEADDID, CommunityAddress.ADDRNUM, CommunityAddress.FULLNAME, CommunityAddress.FULLADDR, CommunityAddress.MUNICIPALITY, MunicipalBoundary.Name, MunicipalBoundary.MUNITYP, MunicipalBoundary.LOCALFIPS",
        using (Geodatabase testVersion1Geodatabase = new Geodatabase(new DatabaseConnectionProperties(EnterpriseDatabaseType.Oracle)
          AuthenticationMode = AuthenticationMode.DBMS,
          Instance = "instance",
          User = "user",
          Password = "password",
          Database = "database",
          Version = "user.testVersion1"
          QueryTableDescription queryTableDescription = new QueryTableDescription(queryDef)
            Name = "CommunityAddrJounMunicipalBoundr",
            PrimaryKeys = testVersion1Geodatabase.GetSQLSyntax().QualifyColumnName("CommunityAddress", "OBJECTID")
          // Will be based on testVersion1.
          using (Table queryTable = testVersion1Geodatabase.OpenQueryTable(queryTableDescription))
            // Use queryTable.
        using (Geodatabase testVersion2Geodatabase = new Geodatabase(new DatabaseConnectionProperties(EnterpriseDatabaseType.Oracle)
          User = "user",
          Version = "user.testVersion2"
            PrimaryKeys = testVersion2Geodatabase.GetSQLSyntax().QualifyColumnName("CommunityAddress", "OBJECTID")
          // Will be based on testVersion2.
          using (Table queryTable = testVersion2Geodatabase.OpenQueryTable(queryTableDescription))
            // Use queryTable.
    Requirements
