ArcGIS.Core.Geometry Namespace / GeometryEngine Class / ReplaceNaNZs Method
The geometry to replace non simple Zs.
The Z-value to assign.
Example
    ReplaceNaNZs Method (GeometryEngine)
    Replaces each non-simple (NaN) Z-value on the geometry with the specified Z-value. All other simple (non-NaN) Z-values are unchanged.
    Syntax
    Public Function ReplaceNaNZs( _
       ByVal geometry As Geometry, _
       ByVal zValue As Double _
    ) As Geometry
    public Geometry ReplaceNaNZs(
       Geometry geometry,
       double zValue
    Parameters
    geometry
    zValue
    Return Value
    A geometry in which each coordinate has a simple (non-NaN) Z-value. If the input geometry is empty, then it is returned unchanged.
    Exceptions
    ExceptionDescription
    Geometry is null.
    The method is not implemented for GeometryBag.
    This geometry is not Z-Aware.
    Remarks
    Use this function in conjunction with IsSimpleAsFeature prior to saving a geometry to a geodatabase.
    Example
    Replace NaN Zs in a polygon
      List<Coordinate3D> coordsZ =
        new Coordinate3D(1, 2, double.NaN),
      new Coordinate3D(4, 5, 3),
      new Coordinate3D(7, 8, double.NaN)
      polygon = PolygonBuilderEx.CreatePolygon(coordsZ);
      // polygon.HasZ = true
      Polygon polygonZReplaced = GeometryEngine.Instance.ReplaceNaNZs(polygon, -1) as Polygon;
      // polygonZReplaced.Points[0].Z = -1
      // polygonZReplaced.Points[1].Z = 3
      // polygonZReplaced.Points[2].Z = -1
    Requirements
