ArcGIS.Core.Geometry Namespace / GeometryEngine Class / IsSimpleAsFeature Method
The geometry to be tested.
(Optional) The default value is false. When true, the geometry will be tested for simplicity even if it has already been tested or simplified. Geometry has a non-persisted internal flag that is set by IsSimpleAsFeature or SimplifyAsFeature calls. The flag is used to avoid computations if the state of the geometry is known.
Example
    IsSimpleAsFeature Method (GeometryEngine)
    Indicates whether this geometry is known to be topologically consistent according to the geometry type for storage in a database.
    Syntax
    Public Function IsSimpleAsFeature( _
       ByVal geometry As Geometry, _
       ByVal forceIsSimple As Boolean _
    ) As Boolean
    public bool IsSimpleAsFeature(
       Geometry geometry,
       bool forceIsSimple
    Parameters
    geometry
    forceIsSimple
    Return Value
    Returns true if the geometry is simple. Otherwise, returns false.
    Exceptions
    ExceptionDescription
    Geometry is null.
    The method is not implemented for GeometryBag.
    Remarks
    See SimplifyAsFeature and IsSimpleAsFeature Pro Concepts topic. Note that NaN Z-values are not taken into account when determining if the geometry is topologically consistent. You should call ReplaceNaNZs on any geometry prior to saving it into a geodatabase.
    Example
    Project from WGS84
      // create the polygon
      List<MapPoint> pts =
        MapPointBuilderEx.CreateMapPoint(1.0, 1.0, SpatialReferences.WGS84),
      MapPointBuilderEx.CreateMapPoint(1.0, 2.0, SpatialReferences.WGS84),
      MapPointBuilderEx.CreateMapPoint(2.0, 2.0, SpatialReferences.WGS84),
      MapPointBuilderEx.CreateMapPoint(2.0, 1.0, SpatialReferences.WGS84),
      polygon = PolygonBuilderEx.CreatePolygon(pts);
      // ensure it is simple
      bool isSimple = GeometryEngine.Instance.IsSimpleAsFeature(polygon);
      // create the spatial reference to project to
      SpatialReference northPole = SpatialReferenceBuilder.CreateSpatialReference(102018);   // north pole stereographic
      // project
      Geometry geometry = GeometryEngine.Instance.Project(polygon, northPole);
    Requirements
