Return Value
Geometry represented as a binary XML string.
// export to binary xml
string binaryXml = multipatch.ToBinaryXml();
// import from binaryXML - methods need to run on the MCT
Multipatch binaryMultipatch = MultipatchBuilderEx.FromBinaryXml(binaryXml);
// xml export / import
string xml = multipatch.ToXml();
Multipatch xmlMultipatch = MultipatchBuilderEx.FromXml(xml);
// esriShape export/import
byte[] buffer = multipatch.ToEsriShape();
Multipatch esriPatch = MultipatchBuilderEx.FromEsriShape(buffer);
// or use GeometryEngine
Multipatch patchImport = GeometryEngine.Instance.ImportFromEsriShape(EsriShapeImportFlags.EsriShapeImportDefaults, buffer, multipatch.SpatialReference) as Multipatch;
