ArcGIS.Core.Geometry Namespace / Multipatch Class
Members
    Multipatch Class
    A class representing a multipatch.
    Object Model
    Multipatch ClassGeometry ClassEnvelope ClassCoordinate3D StructureCoordinate2D StructureReadOnlyPointCollection ClassMapPoint ClassSpatialReference Class
    Syntax
    Public NotInheritable Class Multipatch
       Inherits Geometry
    public sealed class Multipatch : Geometry
    Remarks
    A Multipatch is based upon the parent Geometry class. The Geometry class is immutable which means that you can not change its shape once it is created.
    A multipatch is a series of 3-dimensional surfaces. The surfaces may be represented by triangle strips, triangles fans, groups of triangles or groups of rings. In a multipatch there is one triangle strip, triangle fan, or groups of triangles per surface, whereas there can be one or more rings per surface. A single multipatch may comprise combinations of triangle strips, triangle fans, groups of triangles, or groups of rings.
    Each part in a multipatch is called a patch. A patch can be a triangle strip, triangle fan, a group of triangles, or a ring. See PatchType for more information on patch types.
    Inheritance Hierarchy
    System.Object
       ArcGIS.Core.Geometry.Geometry
          ArcGIS.Core.Geometry.Multipatch
    Requirements
