ArcGIS.Desktop.Core Namespace / IProjectWindow Interface / SelectedItems Property
Example
    SelectedItems Property (IProjectWindow)
    Gets the currently selected Items
    Syntax
    IEnumerable<Item> SelectedItems {get;}
    ReadOnly Property SelectedItems As IEnumerable(Of Item)
    Example
    Geodatabase Content from Catalog selection
      // subscribe to event
      ProjectWindowSelectedItemsChangedEvent.Subscribe(async args =>
        if (args.IProjectWindow.SelectionCount > 0)
          // get the first selected item
          var selectedItem = args.IProjectWindow.SelectedItems.First();
          var mapView = MapView.Active;
          await QueuedTask.Run(() =>
            // datasetType
            var dataType = ItemFactory.Instance.GetDatasetType(selectedItem);
            // get the dataset Definition
            if (ItemFactory.Instance.CanGetDefinition(selectedItem))
              using var def = ItemFactory.Instance.GetDefinition(selectedItem);
              if (def is FeatureClassDefinition fcDef)
                var oidField = fcDef.GetObjectIDField();
                var shapeField = fcDef.GetShapeField();
                var shapeType = fcDef.GetShapeType();
              else if (def is ArcGIS.Core.Data.Parcels.ParcelFabricDefinition pfDef)
                string ver = pfDef.GetSchemaVersion();
                bool enabled = pfDef.GetTopologyEnabled();
            // get the dataset
            if (ItemFactory.Instance.CanGetDataset(selectedItem))
              using var ds = ItemFactory.Instance.GetDataset(selectedItem);
              if (ds is FeatureDataset fds)
                // open featureclasses within the feature dataset
                // var fcPoint = fds.OpenDataset<FeatureClass>("Point");
                // var fcPolyline = fds.OpenDataset<FeatureClass>("Polyline");
              else if (ds is FeatureClass fc)
                var name = fc.GetName() + "_copy";
                // create
                var featureLayerParams = new FeatureLayerCreationParams(fc)
                  Name = name,
                  MapMemberIndex = 0
                LayerFactory.Instance.CreateLayer<FeatureLayer>(featureLayerParams, mapView.Map);
              else if (ds is Table table)
                var name = table.GetName() + "_copy";
                var tableParams = new StandaloneTableCreationParams(table)
                  Name = name
                // create
                StandaloneTableFactory.Instance.CreateStandaloneTable(tableParams, mapView.Map);
    Requirements
