ArcGIS.Desktop.Core Namespace / SignInResult Class
Members Example
    SignInResult Class
    Contains the status of the Portal SignIn. This includes the success of failure of the SignIn and the current token (if succesfull)
    Syntax
    Public Class SignInResult
    public class SignInResult
    Example
    ArcGISPortalManager: Get a portal and Sign In, Set it Active
      //Find the portal to sign in with using its Uri...
      var uri = new Uri("http://myportal.esri.com/portal/", UriKind.Absolute);
      var aPortal = ArcGISPortalManager.Current.GetPortal(uri);
      if (!aPortal.IsSignedOn())
        //Calling "SignIn" will trigger the OAuth popup if your credentials are
        //not cached (eg from a previous sign in in the session)
        if (portal.SignIn().success)
          //Set this portal as my active portal
          ArcGISPortalManager.Current.SetActivePortal(portal);
    Inheritance Hierarchy
    System.Object
       ArcGIS.Desktop.Core.SignInResult
    Requirements
