Return Value
A SignInResult containing the SignIn status
| Exception | Description |
| ArcGIS.Core.CalledOnWrongThreadException | Thrown when a method is called on the wrong Pro thread |
//Find the portal to sign in with using its Uri...
var uri = new Uri("http://myportal.esri.com/portal/", UriKind.Absolute);
var aPortal = ArcGISPortalManager.Current.GetPortal(uri);
if (!aPortal.IsSignedOn())
//Calling "SignIn" will trigger the OAuth popup if your credentials are
//not cached (eg from a previous sign in in the session)
if (portal.SignIn().success)
//Set this portal as my active portal
ArcGISPortalManager.Current.SetActivePortal(portal);
//Force login
if (!portal.IsSignedOn())
portal.SignIn();
var user = portal.GetSignOnUsername();
