ArcGIS.Desktop.Core Namespace / ArcGISPortal Class
Properties Methods
    ArcGISPortal Class Members
    The following tables list the members exposed by ArcGISPortal.
    Public Properties
     NameDescription
    Public Property Gets the portal Uri for this portal instance
    Top
    Public Methods
     NameDescription
    Public Method Ensure the portal is a valid.
    Public MethodGets the username for the current connection This method should be called from within a QueuedTask or System.Threading.Task unless the caller is within ArcGIS.Desktop.Framework.Contracts.ConfigurationManager.OnApplicationInitializing in which case the main thread should be used.
    Public MethodGets the current token for the session. The ArcGISPortal class automatically manages the token expiration. This value should not be cached. This method should be called from within a QueuedTask or System.Threading.Task unless the caller is within ArcGIS.Desktop.Framework.Contracts.ConfigurationManager.OnApplicationInitializing in which case the main thread should be used.
    Public Method Gets whether this portal instance is the active portal
    Public Method Gets whether this portal instance is avilable to connect to its end point.
    Public MethodGets the sign on status of the portal instance. This method should be called from within a QueuedTask or System.Threading.Task unless the caller is within ArcGIS.Desktop.Framework.Contracts.ConfigurationManager.OnApplicationInitializing in which case the main thread should be used.
    Public Method Synchronous method to Sign on to this portal instance.
    Public Method Asynchronous method to Sign on to this portal instance.
    Public Method Synchronous method to Sign on to this portal instance. This method must be called from within a QueuedTask or BackgroundTask.
    Public MethodSign out from this portal instance This method should be called from within a QueuedTask or System.Threading.Task unless the caller is within ArcGIS.Desktop.Framework.Contracts.ConfigurationManager.OnApplicationInitializing in which case the main thread should be used.
    Top
    Extension Methods
     NameDescription
    Public Extension Method Gets the list of base maps that are configured for the given portal.
    Public Extension Method Gets the groups from the user's community information.
    Public Extension MethodExecutes a self query on the specified portal to return its ArcGIS.Desktop.Core.Portal.PortalInfo.
    Public Extension Method Gets the given username's content. Items are either in the home folder for the user, e.g. /content/users/{username} or in a subfolder of the home folder with the given folder ID. Multilevel folders are not supported.
    Public Extension Method Searches for portal items from a query string.
    Top
