ArcGIS.Desktop.Framework.Contracts Namespace / ConfigurationManager Class / OnApplicationInitializing Method
Returning false signals a problem has occurred and the application should shut down.
    Called when the application is initializing. It is safe to communicate with Portal at this time. The DAML records have not been processed at this point.
    Syntax
    Protected Friend Overridable Sub OnApplicationInitializing( _
       ByVal cancelEventArgs As CancelEventArgs _
    protected internal virtual void OnApplicationInitializing(
       CancelEventArgs cancelEventArgs
    Parameters
    cancelEventArgs
    Requirements
