ArcGIS.Desktop.Mapping Namespace / MappingExtensions Class / GetAvailableTopologiesAsync Method
The map to retrieve the topology properties for.
Example
    Gets the list of available topologies for the map. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Shared Function GetAvailableTopologiesAsync( _
       ByVal map As Map _
    ) As Task(Of IReadOnlyList(Of TopologyProperties))
    public static Task<IReadOnlyList<TopologyProperties>> GetAvailableTopologiesAsync(
       Map map
    Parameters
    map
    Return Value
    The list of topology properties for the map.
    Exceptions
    ExceptionDescription
    Map is null
    Remarks
    Topologies are only supported if the map is a 2D non-stereo map. If the map contains geodatabase topology layers then geodatabase topology properties are also returned.
    Example
    Get List of available topologies in the map
    // Retrieves and processes the list of available topologies in the active map.
    await QueuedTask.Run(async () =>
      var map = MapView.Active.Map;
      //Get a list of all the available topologies for the map
      var availableTopologies = await map.GetAvailableTopologiesAsync();
      var gdbTopologies = availableTopologies.OfType<GeodatabaseTopologyProperties>();
      var mapTopologies = availableTopologies.OfType<MapTopologyProperties>();
    Requirements
    ArcGIS Pro version: 3.1 or higher.
