ArcGIS.Desktop.Core Namespace / ArcGISPortalManager Class / GetActivePortal Method
Example
    Get the currently active portal. This is the portal that has been set as the Active Portal either via the API or on the "Portals" backstage tab.
    Syntax
    Public Function GetActivePortal() As ArcGISPortal
    public ArcGISPortal GetActivePortal()
    Return Value
    Remarks
    If an active portal has never been set then, by default, the active portal will be ArcgisOnline
    Example
    ArcGISPortalManager: Get the Current Active Portal
      var active_portal = ArcGISPortalManager.Current.GetActivePortal();
      string uri = active_portal.PortalUri.ToString();
    Requirements
