Public Function GetPortal( _ ByVal portalUri As Uri _ ) As ArcGISPortal
public ArcGISPortal GetPortal( Uri portalUri )
Parameters
- portalUri
- The URI that will be used to search for a matching portal
projectPath = @"https://<userName>.<domain>.com/portal/sharing/rest/content/items/1a434faebbe7424d9982f57d00223baa";
string docVer = string.Empty;
// A portal project path looks like this:
//@"https://<ServerName>.<Domain>.com/portal/sharing/rest/content/items/1a434faebbe7424d9982f57d00223baa";
//A local project path looks like this:
//@"C:\Users\<UserName>\Documents\ArcGIS\Projects\MyProject\MyProject.aprx";
//Check if the project can be opened
if (Project.CanOpen(projectPath, out docVer))
//Open the project
Project.OpenAsync(projectPath);
else //The project cannot be opened
//One possible reason: If the project is a portal project, the active portal must match the portal of the project
//Check if this is a portal project
bool isPortalProject = Uri.TryCreate(projectPath, UriKind.Absolute, out Uri uriResult)
&& (uriResult.Scheme == Uri.UriSchemeHttp || uriResult.Scheme == Uri.UriSchemeHttps);
if (isPortalProject)
//Parse the project path to get the portal
var uri = new Uri(projectPath);
var portalUrlOfProjectToOpen = $"{uri.Scheme}://{uri.Host}/portal/";
//Get the current active portal
var activePortal = ArcGISPortalManager.Current.GetActivePortal();
//Compare to see if the active Portal is the same as the portal of the project
bool isSamePortal = activePortal != null && activePortal.PortalUri.ToString() == portalUrlOfProjectToOpen;
if (!isSamePortal) //not the same.
//Set new active portal to be the portal of the project
//Find the portal to sign in with using its Uri...
var projectPortal = ArcGISPortalManager.Current.GetPortal(new Uri(portalUrlOfProjectToOpen, UriKind.Absolute));
// Note: Needs QueuedTask to run
if (!projectPortal.IsSignedOn())
//Calling "SignIn" will trigger the OAuth popup if your credentials are
//not cached (eg from a previous sign in in the session)
if (projectPortal.SignIn().success)
//Set this portal as my active portal
ArcGISPortalManager.Current.SetActivePortal(projectPortal);
return;
//Now try opening the project again
else
System.Diagnostics.Debug.WriteLine("The project cannot be opened.");
else //The portals are the same. So the problem could be something else - permissions, portal is down?
else //Project is on disk and cannot be opened.
var projectPortal = ArcGISPortalManager.Current.GetPortal(new Uri(@"https://<serverName>.<domain>.com/portal/", UriKind.Absolute));
string owner = string.Empty;
//Get the signed on user name
owner = projectPortal.GetSignOnUsername();
//Get the user content from the portal
PortalUserContent userContent = projectPortal.GetUserContentAsync(owner).Result;
//Get the first portal project item
var firstPortalProject = userContent.PortalItems.FirstOrDefault(pi => pi.PortalItemType == PortalItemType.ProProject);
var portalProjectUri = firstPortalProject.ItemUri.ToString();
//Check if project can be opened
if (Project.CanOpen(portalProjectUri, out docVer))
Project.OpenAsync(portalProjectUri);
//Note: If Project.CanOpen returns false, the project cannot be opened. One reason could be
// the active portal is not the same as the portal of the project. Refer to the snippet: [Workflow to open an ArcGIS Pro project](ProSnippets-sharing#workflow-to-open-an-arcgis-pro-project)
var uri = new Uri("http://myportal.esri.com/portal/", UriKind.Absolute);
var aPortal = ArcGISPortalManager.Current.GetPortal(uri);
if (!aPortal.IsSignedOn())
if (portal.SignIn().success)
ArcGISPortalManager.Current.SetActivePortal(portal);
var myPortal = ArcGISPortalManager.Current.GetPortal(new Uri("https://machine.domain.com/portal/"));
var portalInfo = await myPortal.GetPortalInfoAsync();
var orgid = portalInfo.OrganizationId;
