ArcGIS.Desktop.Mapping Namespace / MappingExtensions Class / UpdateOverlay Method / UpdateOverlay(MapView,IDisposable,CIMGraphic,Double,Double) Method
The view containing the overlay.
The IDisposable instance returned from an AddOverlay method call.
The graphic to be used for the update
Map reference scale or -1
Visibility factor for showing the overlay through other objects when obscured in 3D.
Valid range is [0..1], any other value will be treated as 0 (not visible).
    Updates the graphic for an overlay graphic on the map view.
    Syntax
    Public Overloads Shared Function UpdateOverlay( _
       ByVal mapView As MapView, _
       ByVal disposable As IDisposable, _
       ByVal graphic As CIMGraphic, _
       ByVal referenceScale As Double, _
       ByVal showThrough As Double _
    ) As Boolean
    Parameters
    mapView
    disposable
    graphic
    referenceScale
    showThrough
    Return Value
    True if the overlay was updated. False otherwise.
    Remarks
    When the referenceScale is not equal to -1, the overlay will be created in real world units relative to the provided map reference scale (referenceScale). Otherwise, the overlay will be created in units of points. This is only supported in 2D.
    Requirements
    ArcGIS Pro version: 3.1 or higher.
