ArcGIS.Desktop.Core.Events Namespace / ActivePortalChangedEvent Class / Subscribe Method
The delegate to be executed when the event is published.
When false the ArcGIS.Core.Events.CompositePresentationEvent<TPayload> will maintain a weak delegate reference to the subscriber. Using a weak delegate reference relieves the subscriber from the need to unsubscribe to enable proper garbage collection.
Example
    Subscribe Method (ActivePortalChangedEvent)
    Subscribe to the ActivePortalChangedEvent.
    Syntax
    Parameters
    action
    keepSubscriberAlive
    Return Value
    A ArcGIS.Core.Events.SubscriptionToken that uniquely identifies the added subscription.
    Example
    ArcGISPortalManager: Listen for the Portal Events
      ArcGIS.Desktop.Core.Events.ActivePortalChangedEvent.Subscribe((args) =>
        var active_uri = args.ActivePortal?.PortalUri.ToString();
        //etc
      ArcGIS.Desktop.Core.Events.ArcGISPortalAddedEvent.Subscribe((args) =>
        var added_portal = args.Portal;
        //etc
      ArcGIS.Desktop.Core.Events.ArcGISPortalRemovedEvent.Subscribe((args) =>
        var old_uri = args.RemovedPortalUri;
        //etc
      ArcGIS.Desktop.Core.Events.PortalSignOnChangedEvent.Subscribe((args) =>
        var portal = args.Portal;
        var isSignedOn = args.IsSignedOn;
        //etc
    Requirements
