ArcGIS.Desktop.Mapping Namespace / CatalogLayerCreationParams Class / DefinitionQuery Property
Example
    DefinitionQuery Property (CatalogLayerCreationParams)
    Gets and sets a definition query with name.
    Syntax
    Public Property DefinitionQuery As DefinitionQuery
    public DefinitionQuery DefinitionQuery {get; set;}
    Example
    Create Catalog Layer using Uri to a Catalog Feature Class
        var createParams = new CatalogLayerCreationParams(new Uri(@"C:\CatalogLayer\CatalogDS.gdb\HurricaneCatalogDS"));
        //Set the definition query
        createParams.DefinitionQuery = new DefinitionQuery("Query1", "cd_itemname = 'PuertoRico'");
        //Set name of the new Catalog Layer
        createParams.Name = "PuertoRico";
        //Create Layer
        //Note: Needs QueuedTask to run
        var catalogLayer = LayerFactory.Instance.CreateLayer<CatalogLayer>(createParams, MapView.Active.Map);
    Create Catalog Layer using CatalogDataset
        //Get the CatalogDataset of another Catalog layer
        var existingCatalogLayer = MapView.Active.Map.GetLayersAsFlattenedList().OfType<CatalogLayer>().FirstOrDefault();
        if (existingCatalogLayer != null)
            var catalogDataset = existingCatalogLayer.GetCatalogDataset();
            //Configure the settings for a new Catalog layer using the CatalogDataset of an existing layer
            var catalogLyrParams = new CatalogLayerCreationParams(catalogDataset);
            catalogLyrParams.Name = "NewCatalogLayerFromAnotherCatalogLayer";
            catalogLyrParams.DefinitionQuery = new DefinitionQuery("Query1", "cd_itemname = 'Asia'");
            LayerFactory.Instance.CreateLayer<CatalogLayer>(catalogLyrParams, MapView.Active.Map);
    Requirements
    ArcGIS Pro version: 3.1 or higher.
