ArcGIS.Desktop.Mapping Namespace / MapMember Class / CanSetTime Method
The time parameters to set.
    CanSetTime Method (MapMember)
    Gets if the mapMember supports time filtering and if the specified time parameters are valid. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Overridable Function CanSetTime( _
       ByVal timeParams As TimeParameters _
    ) As Boolean
    public virtual bool CanSetTime(
       TimeParameters timeParams
    Parameters
    timeParams
    Return Value
    True if the mapMember supports time filtering and the timeParams are valid. False otherwise.
    Exceptions
    ExceptionDescription
    Remarks
    You should use this method before calling the SetTime method.
    The following outlines some of the rules for determining validity of the time parameters with respect to the mapMember
    - The rules as specified in TimeParameters.IsValid.
    - if a StartTimeFieldName is specified it must exist and not be of type ArcGIS.Core.Data.FieldType.TimeOnly.
    - if a EndTimeFieldName is specified it must exist and not be of type ArcGIS.Core.Data.FieldType.TimeOnly.
    - if both StartTimeFieldName and EndTimeFieldName are specified and StartTimeFieldName is of type ArcGIS.Core.Data.FieldType.DateOnly then EndTimeFieldName must also be ArcGIS.Core.Data.FieldType.DateOnly.
    - if both StartTimeFieldName and EndTimeFieldName are specified and StartTimeFieldName is of type ArcGIS.Core.Data.FieldType.TimestampOffset then EndTimeFieldName must also be ArcGIS.Core.Data.FieldType.TimestampOffset.
    - if both StartTimeFieldName and EndTimeFieldName are specified and StartTimeFieldName is of type ArcGIS.Core.Data.FieldType.Date then EndTimeFieldName must not be of type ArcGIS.Core.Data.FieldType.DateOnly or ArcGIS.Core.Data.FieldType.TimestampOffset.
    Requirements
    ArcGIS Pro version: 3.1 or higher.
