ArcGIS.Desktop.Framework.Contracts Namespace / ConfigurationManager Class / OnUpdateDatabase Method
The entire merged DAML database.
    The last chance for the configuration to manipulate the DAML before it is processed.
    Syntax
    Protected Friend Overridable Sub OnUpdateDatabase( _
       ByVal database As XDocument _
    protected internal virtual void OnUpdateDatabase(
       XDocument database
    Parameters
    database
    Remarks
    A configuration may find it necessary to edit the raw database to achieve a desired look. For example, a configuration may want to delete all the tabs in the system except for its own.
    This is the raw DAML database in XML form, edit with extreme caution.
    Requirements
