ArcGIS.Desktop.Mapping Namespace / MosaicLayer Class / CanSetTime Method
The time parameters to set.
    CanSetTime Method (MosaicLayer)
    Gets if the mapMember supports time and if the specified time parameters are valid. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public override bool CanSetTime(
       TimeParameters timeParams
    Public Overrides NotOverridable Function CanSetTime( _
       ByVal timeParams As TimeParameters _
    ) As Boolean
    Parameters
    timeParams
    Return Value
    True if the mapMember supports time and the timeParams are valid. False otherwise.
    Exceptions
    ExceptionDescription
    Remarks
    You should use this method before calling the SetTime method.
    Raster layers do not support TimeParameters.TimeOffset, TimeParameters.StepInterval or TimeIntervalType when only start or end dates are specified.
    Requirements
    ArcGIS Pro version: 3.1 or higher.
