public sealed class MosaicLayer : CompositeLayer, ArcGIS.Desktop.Core.IMetadataInfo, IInternalMosaicLayer, ILayerContainer, IMetadataSource, ITableDefinitionQueries, System.ComponentModel.INotifyPropertyChanged
Public NotInheritable Class MosaicLayer Inherits CompositeLayer Implements ArcGIS.Desktop.Core.IMetadataInfo, IInternalMosaicLayer, ILayerContainer, IMetadataSource, ITableDefinitionQueries, System.ComponentModel.INotifyPropertyChanged
//Path to mosaic dataset
string urlItaly = @"C:\Images\countries.gdb\Italy";
// Create a mosaic layer using a path to a mosaic dataset.
// Note: You can create a mosaic layer from a url, project item, or data connection.
mosaicLayer = await QueuedTask.Run(() =>
LayerFactory.Instance.CreateLayer(new Uri(urlItaly), map) as MosaicLayer);
// Create a new colorizer definition using default constructor. { StretchColorizerDefinition stretchColorizerDef = new StretchColorizerDefinition(); var rasterLayerCreationParams = new RasterLayerCreationParams(new Uri("url")) { Name = "layerRasterName", ColorizerDefinition = stretchColorizerDef, MapMemberIndex = 0 }; // Create a mosaic layer using the colorizer definition created above. // Note: You can create a mosaic layer from a url, project item, or data connection. MosaicLayer newMosaicLayer = await QueuedTask.Run(() => LayerFactory.Instance.CreateLayer<MosaicLayer>(rasterLayerCreationParams, map)); }
System.Object
ArcGIS.Desktop.Framework.Contracts.PropertyChangedBase
ArcGIS.Desktop.Mapping.MapMember
ArcGIS.Desktop.Mapping.Layer
ArcGIS.Desktop.Mapping.CompositeLayer
ArcGIS.Desktop.Mapping.MosaicLayer
