GetZsFromSurfaceAsync(Geometry) Method
Obtains a geometry that is similar to the given input geometry, where some or all Z values are populated from the default Ground Surface Layer.
Syntax
Parameters
- geometry
- The input geometry
Return Value
A result that contains a status, plus an output geometry only if the status is favorable.
Exceptions
Example
Get Z values from the default ground surface
//Note: This method must be called on the MCT
// Get the center of the map's full extent
MapPoint mapPoint = MapView.Active.Map.CalculateFullExtent().Center;
//Pass any Geometry type to GetZsFromSurfaceAsync
var surfaceZResult = await MapView.Active.Map.GetZsFromSurfaceAsync(mapPoint);
if (surfaceZResult.Status == SurfaceZsResultStatus.Ok)
// cast to a mapPoint
var mapPointZ = surfaceZResult.Geometry as MapPoint;
var z = mapPointZ.Z;
Get Z values from a specific surface
var eleLayer = MapView.Active.Map.GetElevationSurfaceLayers().FirstOrDefault(l => l.Name == "TIN");
//Ensure the feature layer is a line layer and is Z aware
var selectedFeatures = featureLayer.GetSelection();
var rowCursor = selectedFeatures.Search();
while (rowCursor.MoveNext())
var feature = rowCursor.Current as Feature;
var polyline = feature.GetShape() as Polyline;
var zResult = await MapView.Active.Map.GetZsFromSurfaceAsync(polyline, eleLayer);
if (zResult.Status == SurfaceZsResultStatus.Ok)
var polylineZ = zResult.Geometry as Polyline;
// process the polylineZ
// For example, you can iterate through the points and access their Z values
Requirements
